Ignition control module question
Old Apr 12, 2015 | 06:45 PM
Barry Hagen's Avatar
Barry Hagen
Hello,
I have been troubleshooting my 85 F150, and ran across a strange issue. The #1 wire (the top wire) off of the TFI has a connector about 5 inches "upstream" that is disconnected and wrapped in electrical tape. Now I bought the truck 3 years ago and It has run very well, until recently. My question is, how could the truck run with this disconnected, isn't that the wire that goes to the PIP? And why would anyone disconnect it in the first place?
Any help would be greatly appreciated!
Thanks,
Barry
Old Apr 12, 2015 | 07:33 PM
Franklin2's Avatar
Franklin2
By disconnecting it, it takes the control of the timing away from the computer and the timing will be locked to a number where the engine will run to get you home. Looks like you have been running in that mode for awhile.
What engine is this?
Old Apr 12, 2015 | 08:30 PM
Barry Hagen
302 2bbl. So should I assume the computer had failed at some point?
Old Apr 13, 2015 | 07:46 AM
ctubutis's Avatar
ctubutis
I wouldn't make that assumption; I suspect somebody was trying to "make it run better" by doing that + disconnecting various vacuum hoses and whatnot.
Old Apr 13, 2015 | 10:32 AM
Franklin2's Avatar
Franklin2
You need to make a decision, whether to try and get your original system going or replace the distributor and ignition system to a older type mechanical system.
handyjohn
Jul 26, 2014 09:37 AM
Gordon Freeman
Jun 27, 2011 08:25 AM
donatorc
Aug 19, 2010 06:36 PM
fomocomo
1983 - 2012 Ranger & B-Series
Sep 20, 2007 08:51 AM
roughcreekgang
Electrical Systems/Wiring
Jul 16, 2005 08:29 AM
