Axle Swap 2006 F250
Old 04-12-2015, 12:33 AM
DSLTRK60's Avatar
DSLTRK60
DSLTRK60 is offline
Axle Swap 2006 F250
Hi all,
My pinion bearings went bad on my 10.5 Sterling after some idiot didn't set preload correctly. Thinking of swapping a low mileage 2011 rear with the e-locker from a donor.
I know the speed sensor is different, but does my truck have ABS in the rear? Does the speed sensor also serve as the abs?
Anything I should watch out for besides the obvious like ratios? Is the yoke the same pattern?
Truck is a 2006 F250 FX4 Crew with short bed.
Thanks
Joe Bleaux
1999 to 2016 Super Duty
10-18-2016 03:13 PM
jaoneill
Escape & Escape Hybrid
07-19-2013 04:14 PM
vandrini
09-12-2011 11:27 AM
fordboy2
03-03-2009 11:15 AM
Ryan50hrl
12-13-2001 06:54 AM
Quick Reply: Axle Swap 2006 F250
