Hard start when cold 2006 250
Old Apr 11, 2015 | 09:09 PM
jrcastaneda's Avatar
jrcastaneda
Hello all i found a post the other day and couldn't find it even when searched. When it's usually in the low 30's my 2006 250 has a hard start. I'll wait for the glow plugs to warm up then it'll crank for a little while. Then I'll stop and try again. It'll turn over then shut off. By the third time it usually fires right up. Later in the day it doesn't have this issue even after sitting for awhile. After it starts up a little bit of black smoke comes out of the exhaust. Didn't notice the black smoke previously but checked this morning and there was a little. Still waiting for my edge insight to deliver so can't test for any codes. Thanks for any advice.
-John
Old Apr 11, 2015 | 09:17 PM
nmclella's Avatar
nmclella
Does it sound like this? This isn't when it was at its worst, as I would sometimes have to give it 2-3 tries before it would stay going without a rough stall. I had a bad FICM, and also have some continuing stiction problems.
Old Apr 11, 2015 | 09:33 PM
jrcastaneda
Thanks for the quick response.It's hard to hear on the video but kind of sounds like that. Sometimes doesn't rattle like that though. With my edge insight will it pick up on the FICM if it's going bad?
Old Apr 12, 2015 | 07:13 AM
jrcastaneda
I also read in the tech folder under ficm test that usually there won't be smoke when it's the ficm.
Old Apr 12, 2015 | 07:20 AM
78fordman's Avatar
78fordman
Test ficm voltage, watch while cranking. It should stay about 45. Do you have any consistent cylinder contribution codes? Are there any glow plug codes?
Old Apr 12, 2015 | 07:38 AM
jrcastaneda
Should be getting my insight in the next week so have to wait to test for any codes. I'll test as soon as I get it. Thanks for the reply
EDIT: I noticed you put voltage I can do that with my multimeter. Still waking up.
Last edited by jrcastaneda; Apr 12, 2015 at 07:49 AM. Reason: noticed something about previous reply
Old Apr 12, 2015 | 06:32 PM
jrcastaneda
Tested the FICM with my volt meter it tested 48 volts. When reinstalling my coolant reservoir it doesn't look right. Looks like the reservoir is tilted up slightly. Don't think it was tilted like that when I in bolted the bolts to move it to the side for the FICM test
djbucky3
Jul 11, 2014 11:01 PM
RedDevil460
Sep 20, 2013 07:52 PM
JamesHajek
Jan 20, 2010 11:51 PM
98SurplusExpy
Dec 4, 2009 09:24 PM
true blue
24
Nov 26, 2006 07:57 PM
