I would like to drop the front 2-3 in and level the rear. Im pretty sure it has the original springs. Fender to ground on the front is 31 in, the rear is 34.5 in. Tires are L78-15, 28.3 in tall.
On the front, from the top of the spring pack to the bump stop is 2.25 in. There is very little arch to the springs. The bump stop is the oem rubber.
The only way I see to lower the front and have a safe driver is to use a dropped axle.
On the rear I could flip the hanger or reverse the eye and use a longer shackle.
I don't want to cut the frame.
By the time I buy a dropped axle, tie rod ends, and a center link, how much have I got into this for a 3 in drop?
You could go the Crown VIC front end route (that is what I am doing). From what I have read on here that could be 3-5 inch drop in the front and you can get them for $300-400. I just picked up a complete front end for $300. Then you get coil spring front end, rack and pinion steering, disc brakes.
For the rear, I have the same problem...to get it leveled or lowered, there isn't much room if you flip the axle and then leaving room for suspension travel. Sounds like most guys cut the frame, put in a C-notch, etc. I am still trying to figure out what I want/need to do to get the rear level.
I dropped the rear with a set of 2in shackles. I have a set of new leaf springs for the front that I haven't installed yet. I like the stance for now. Maybe a drop axle and a rear flip someday, but Im happy for now.
