RABS/Flushing system
Old Apr 11, 2015 | 05:31 PM
Dennis-Pa's Avatar
Dennis-Pa
I have a 94 F-250,4x4 I flushed the brake system today and after that the ABS light & brake light came on. I sucked out as much fluid as I could with a baster then bleed the brakes.I'm sure I must of disturbed some crud in the master cyl. and it must of got into the ABS module.Is the anything I can do to fix it.
Old Apr 12, 2015 | 09:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
there is a bleeding valve on the RABS unit. bleed pass rear, then driver rear, then RABS, then pass front, and finally driver front. this SHOULD reset the RABS plunger the turn the light off.
Old Apr 13, 2015 | 04:42 AM
EPNCSU2006's Avatar
EPNCSU2006
With both of those lights on, the first thing to check is the float switch in the master cylinder and its connector and wiring.
forddriverdad
Jun 28, 2012 06:11 PM
The_Ford_Driver
Aerostar
Apr 24, 2012 09:27 PM
gbeau626
Apr 9, 2010 10:18 AM
dageabse
Aerostar
Nov 3, 2004 10:41 PM
biederboat
Aerostar
Oct 19, 2003 02:16 PM
