Clutch Pedal Problem
Old Apr 9, 2015 | 03:22 PM
Horsefly the Old Guy's Avatar
Trailering
Here's my ongoing problem, had clutch, slave cylinder, throwout bearing pilot bearing replaced last year. 1,000 miles later clutch is toast again. After removal the clutch was shredded, like hash brown potatoes if you will. Replaced everything I mentioned before and now 3 times in a hundred miles my clutch pedal freezes. Mechanic states it's throwing the line at the connection under the driver's side of the cab. After last time he states the connection has been redesigned looks good now. I state clutch pedal does not feel right. Everyone except myself says it's fine, I've owned this truck for over 10 basically trouble free years, 108,000 miles no kids hammering on it. They soften me up a bit by bleeding the system and now a hundred miles later the pedal freezes and after I push it a bit pops and goes all the way to the floor ? Don't want a fight over this but, I'm stumped, Thanks.
Old Apr 9, 2015 | 03:38 PM
Stevaroo01's Avatar
Stevaroo01
Have you checked the master cylinder? If there is damage inside the mc it may be working intermittently and causing this catching/popping experience. It also may be causing your clutch to not fully engage when you release the clutch pedal which would cause some clutch slipping and ultimately burn up your new clutch. Just a thought...
Old Apr 9, 2015 | 04:03 PM
Trailering
The rod from the slave cylinder resevoir to the pedal is broken, the new one is all metal, doesn't help with the connection repeatedly popping off, would the master cylinder cause this?
Old Apr 9, 2015 | 05:57 PM
ncranchero's Avatar
ncranchero
Worn pedal shaft bushings. I'm going through that now. Hopefully I'll get new bushings installed this weekend.
I started to half-a** it with that heim joint rig but decided to fix it right. I put the steel pushrod in mine and in a month it had ripped the bushing/retainer out
Of course if that coupling at the slave cylinder closed internally you would have broken the clutch rod by pushing on it hard.
The hydraulic line coupling self-seals just like a hydraulic line on a tractor.
coupler
http://i1240.photobucket.com/albums/...psqntlyjxf.jpg
http://i1240.photobucket.com/albums/...pswqza9zge.jpg
http://i1240.photobucket.com/albums/...ps7ckadsea.jpg
Old Apr 9, 2015 | 07:03 PM
Trailering
Yes, I believe you are correct, so I replace the white bushing in the third photo and all is well? Still a bit confused as to why the connector keeps popping off.
Old Apr 9, 2015 | 07:32 PM
ncranchero's Avatar
ncranchero
You get all of the bushings in a kit, F3TZ2C342A, except the one that goes on the pushrod and it can be had in Dorman #14041. The fingers on that bushing, photo 1, are the only thing that holds the rod on. Wear/mis-alignment of the pedal shaft FUBARS the bushing and off the rod comes.
http://www.ebay.com/itm/1992-1997-Ford-F150-F250-F350-Clutch-Pedal-Bushing-Repair-Kit-OEM-NEW-F3TZ2C342A-/201263946453?hash=item2edc441ad5&vxp=mtr
Old Apr 25, 2015 | 08:23 AM
Trailering
Thanks, problem appears to have been misalignment/ non-compatability between the connecting rod on the clutch pedal and the master cylinder, both after market. This pressure also flexed the line popping it off at the connector just under the cab. We'll see. Seems like a problem that would've been redesigned.
crunky944
Jul 8, 2012 09:33 PM
Gomer1
Oct 4, 2011 09:43 AM
firemanbird
Aug 10, 2006 12:33 PM
1bad67cat
1978 - 1996 Big Bronco
Oct 15, 2004 02:12 PM
