Limited-slip differential check
Old Jul 25, 2003 | 11:38 PM
hanajack's Avatar
hanajack
I have a 250 and a 350 with limited-slip.
[1]: How does one determine the condition of the clutches; and, [2]: what is involved in changing them if worn or shot?
Old Jul 25, 2003 | 11:44 PM
MustangGT221's Avatar
MustangGT221
Is this for a ford traction lok?
Old Jul 26, 2003 | 08:27 PM
hanajack's Avatar
hanajack
Yes, both are traction lok.
Old Jul 26, 2003 | 09:34 PM
StrangeRanger's Avatar
StrangeRanger
Jack up one rear wheel, put the tranny in neutral. Use your torque wrench to try to turn the raised wheel. If it takes more than 20 ft-lbs before the wheel breaks loose, the clutches don't need replaced yet.
Replacing the clutch packs can be done with the carrier in place. It's not a real difficult or complicated job.
Old Jul 27, 2003 | 11:47 AM
hanajack's Avatar
hanajack
Thanks StrangeRanger for the help.
The 350 van is a Pathfinder 4 x 4 conversion. Could I use the same procedure to determine if the front has limited-slip?
Old Jul 27, 2003 | 11:56 AM
StrangeRanger
Yes
Nick2005f250
Jan 19, 2014 07:06 PM
buckwhisperer
1978 - 1996 Big Bronco
Feb 20, 2011 06:06 PM
scarab22-1998
1997 - 2003 F150
Jan 12, 2007 11:41 AM
TOMHONE
2004 - 2008 F150
Oct 24, 2006 06:02 PM
kenhd
1997 - 2003 F150
Aug 4, 2001 08:55 AM
