Bill's Clock Repair
Until a few weeks ago when winding it, a horrible screech, and no more workie. It isn't so easy to find a good clock repair shop these days, so after looking at it dead on the wall for a few weeks, I decided to tear into it myself.
Easy enough to pull the hands off, pull 3 screws to remove the dial face, and the actual clock works comes out easily.
The problem was sure to be a broken mainspring, just judging by the noise it made when it broke. And that was quickly confirmed. Fortunately nothing else was damaged.
The spring had broken about 4" from the outer end. I thought about trying to simply lose that 4" and reattach the loop to the remaining spring, but it wasn't going to be easy to punch a tiny hole in that spring steel. A google session found a good source of a wide selection of mainsprings. Found a perfect fit for about $20 delivered to my door.
The clock is a New Haven, made in the good 'ole US of A.
The mainsprings seem to be fairly universal in design, either a loop end, or a hole end style, but there is a wide variety of sizes to choose from. You just need to measure the thickness, width, and length. Length is the hard one to figure. This one is about 8' long and not easy to straighten out without getting cut. Instead of doing that, I measured the diameter of every coil, calculated the length of each coil, and just added those up. This one is about 96" long, 3/4" wide, and 0.018" thick.
By the way, I took all these photos (and more) not to share here, but so I could remember how to get the thing back together. Figured I might as well share them too.
Got the mainspring in just a couple of days, and put it all together tonight. Cleaned and lubed everything while I had it open. She fired right up, and has been tic tocing away for a few hours now. Timekeeping seems in the ballpark, but I expect to have to do a little regulating over the new few weeks.
So many skills being lost every day by America.
Anybody that can fix anything is almost surely from "The Old Country"
Pop
Found this site, which seems pretty good for old clocks.
Antique Clocks Price Guide - Grandfather Wall and Mantel
Found this one,
Antique Clock Details
and this one,
They both look like ours, except they have REGULATOR on the glass and ours has STANDARD TIME.
They want money to give you any real info, and I'm too cheap for that trap.
Found one on eBay:
http://www.ebay.com/itm/Antique-Large-New-Haven-REFEREE-Wall-Clock-Key-Pendulum-Circa-1910-/301531079259?pt=LH_DefaultDomain_0&hash=item4634a7225b
