1978 4bbl Holley....Im back
Old Apr 8, 2015 | 06:57 PM
mr78F150's Avatar
mr78F150
I know I have been asking questions a lot so now I am back with another one. I have my carb running finally, while it is idling I do not feel or see any problems. When I go to put the truck into gear it wants to shut off.......why? If I put it back in N or Park no problems.
Thanks for the help
Old Apr 8, 2015 | 07:47 PM
redneck_davis's Avatar
redneck_davis
You set your idle speed while in gear with e brake/wheels chocked or you set it while in park/neutral??
Just a suggestion. Add your truck w engine/trans specs to your Sig. It'll make it easier on us to help
Old Apr 29, 2015 | 10:34 PM
mr78F150's Avatar
mr78F150
I have set the truck in gear and had a neighbor turn the curb idle but that makes it idle higher when in N or P. But still seems not to be running right when you want to drive it. I really could use some help in this anyone out there?
Old Apr 29, 2015 | 10:38 PM
bkaul's Avatar
bkaul
If you set the idle speed while in gear, it should be that way any time it's in gear ... was it fully warmed up when you did that, or still choked/on the cold idle? Either way ... bump your warm idle setting up a bit and see how that goes.
Old Apr 29, 2015 | 10:40 PM
mr78F150's Avatar
mr78F150
I let the truck warm up to full temp and then i put it into gear while he turned the curb idle. The idle got high when we put into park or neutral. but when i put it into gear it seems like somewhat leveled out. does that help?
Old Apr 29, 2015 | 10:55 PM
bkaul's Avatar
bkaul
That's as it should be... so what's different between what you did there and what you do when it wants to die on you?
Old Apr 29, 2015 | 11:01 PM
mr78F150's Avatar
mr78F150
with curb idle turned up now the regular idle is to high. also it still seems like to stutters while in drive or while being put into drive
Old Apr 29, 2015 | 11:16 PM
bkaul's Avatar
bkaul
I'm not sure what you mean by "regular" idle as opposed to curb? You don't like it idling higher in P/N? It's going to ... there's no separate adjustment for that. What speed are you idling at?
"Stutters" in what conditions? Just sitting there idling, or at throttle tip-in, or under load, or ...? Could be a mixture issue... hard to say without more info.
Old Apr 29, 2015 | 11:20 PM
mr78F150's Avatar
mr78F150
I am not sure the RPM because I don't have a tach. But I do no that under load driving down the road it feels like crap. Then when I come to a stop place the brakes on it wants to die so I need to put it in neutral
Old Apr 30, 2015 | 05:58 AM
jannem's Avatar
jannem
Have you tried adjusting the idle mixture screws?
Old Apr 30, 2015 | 06:08 AM
mr78F150's Avatar
mr78F150
Yes of course. I have those turned almost all the way in
Old Apr 30, 2015 | 07:37 AM
jannem's Avatar
jannem
Try opening them up to see if it has an impact.
Old Apr 30, 2015 | 08:14 AM
mr78F150's Avatar
mr78F150
When I open them up the idle goes way up.
Old Apr 30, 2015 | 08:29 AM
bkaul's Avatar
bkaul
Have you checked for vacuum leaks?
Old Apr 30, 2015 | 08:33 AM
mr78F150's Avatar
mr78F150
I feel like I have taken care of all leaks. But I guess I need to bust out the spray bottle and start spraying stuff to see what I get.
