Minimum compression to get 272 to fire?
Old Apr 8, 2015 | 10:05 AM
Connecticut Calvin's Avatar
Connecticut Calvin
Hi folks - As some of you know by now, my '56 F500 sat for nearly 20 years in a field. The engine wasn't stuck, but I knew it wasn't going to fire with just fresh fuel and a new battery.
The compression in the 272 is very poor; and in 5 cylinders non-existent. The entire driver's side was 0 across the board.
The passenger was: 60, 0, 50, 60.
I took the plugs out and soaked Marvel Mystery Oil in each for 24 hours. I was able to do a compression test on the passenger side this morning before a downpour started.
The passenger side then read 120, 30, 70, 70. So we're making progress.
The question: What is the minimum compression needed for the engine to fire? I'm hope everything will loosen up with multiple fluid changes and clean fuel (with MMO added to both oil and fuel) once it's running. I keep reading that a few short trips with fluid changes in between really clean things up well.
Old Apr 8, 2015 | 10:10 AM
David7.3's Avatar
David7.3
You more than know that you have stuck piston rings, valves stuck and not seating, you can soak everything with marvel mystery oil, Tap on the valves with a rubber hammer, gotta get everything moving again, If you can get to 125 psi you can get her running.
Old Apr 8, 2015 | 10:21 AM
Connecticut Calvin
Yup, very aware of the condition the motor would be in for sure. Glad to see a target number. At least one cylinder is back from the dead. I'll do more soaking and tapping.
I'm curious to see if any of those driver's side cylinders come up. any increase means something is working. I'll update after this afternoon's test, presuming the rain stops.
THANK YOU!
Old Apr 8, 2015 | 01:46 PM
Harrier's Avatar
Harrier
My build thread has info and questions on my compression and trying to get my Y-block started.
Here is where that discussion starts.
https://www.ford-trucks.com/forums/1...l#post11985687
Here are compression numbers:
Cylinder Before After oil After Valve Lash
1 55/0 0 125
2 60 85 115
3 60 75 95
4 75 95 125
5 55 65 85
6 55 90 100
7 65 100 105
8 65 95 105
The third set of numbers are most likely the compression I had when it finally started for the first time.
Old Apr 8, 2015 | 02:45 PM
c91x's Avatar
c91x
100 is usually the minimum you look for. If you have a leak down tester you can see where each cylinder is losing compression.
Old Apr 8, 2015 | 02:51 PM
Connecticut Calvin
1 55/0 0 125
2 60 85 115
3 60 75 95
4 75 95 125
5 55 65 85
6 55 90 100
7 65 100 105
8 65 95 105
Dude. I just watched your "first start" video and I can't stop cracking up to your reaction when your old girl fired up! I can only imagine the feeling. I'm not there yet. But I'm hoping I can get the compression up. Thanks for the link to your thread by the way. Very useful!
Old Apr 8, 2015 | 03:21 PM
F100Jay's Avatar
F100Jay
just been through your Youtube channel..your reaction to it starting for the first time was epic. I almost felt like i was there with you
Old Apr 8, 2015 | 05:12 PM
Harrier's Avatar
Harrier
Thanks guys. It was very exciting finally getting it to start up after 40 years of silence. I thought about editing that part out, but I had to share my excitement after tinkering with it for so long.
Calvin, be sure to take a video of your first start. I have a bunch of videos of nothing happening or backfires or some other odd situation before my first full start.
Old Apr 9, 2015 | 05:28 PM
Connecticut Calvin
Joe I most certainly will post a video of the engine firing! I'd probably get just as excited as you did too I bet!
I dropped the oil pan today so I could clean out whatever goo might have been in the bottom of the pan and also wanted to get a god look at the lower end. Other than 3" of sludge in the pan I was so pleasantly pleased at how clean the engine was. Pistons looked shiny as did the cylinder walls that I could see. I was about to reinstall the pan with its new gasket and seals when I decided to do a quick check on the timing chain. The driver's side was tight but the passenger's side seemed uncomfortably loose. That concerned me. I left the pan off for now so I could take a look at the '56 truck manual. Seems 1/2" deflection or less is acceptable. I'm at more like 3/8" so I'm OK for now.
Old Apr 11, 2015 | 11:21 AM
Connecticut Calvin
IT'S ALIIIIVVVVEEEE!!!! BWAH HAHAHAHAHA!!!!
Well, Ethel has been resurrected! She runs! Kinda. After two oil flushes and a new oil filter, several soaking sessions of Marvel Mystery Oil I was only able to make a dent in the compression issue. I now have 120, 60, 90, 90 in the passenger side. It was 120, 30, 70, 70. Driver side was a big fat ZERO across all four cylinders. Now at 30, 60, 70, 60. It seems the Marvel is doing its thing. I imagine a few cylinders are simply not firing which is why it sounds so rough. Any suggestions or thoughts?
By the way my heart is banging from all the excitement!
Old Apr 11, 2015 | 11:27 AM
raytasch's Avatar
raytasch
Believe Nothing
Congratulations on getting it to run. Your next step should be to ascertain the rockers are getting lubrication. Continue with the Mystery oil. It may get better.
Old Apr 11, 2015 | 11:34 AM
Connecticut Calvin
THANK YOU! I believe if I remove the valve covers I should see a little oil seeping through the center of the rockers. Am I correct?
I'm not going to hurt anything running it for short periods while I verify these things am I?
I'm more of an antique Farmall tractor kind of guy. I'm learning as I go so forgive the questions that might seem silly to most.
Old Apr 11, 2015 | 11:50 AM
raytasch's Avatar
raytasch
Believe Nothing
You have a very basic OHV V8 engine. If it is oiling enough, you will see oil being thrown off the rocker arms when the engine is running. Be sure you have oil at the rockers at both ends of the rocker shafts. Won't hurt a thing.
Old Apr 11, 2015 | 11:57 AM
Connecticut Calvin
Got it. And thank you. I'll take the valve covers off and look closer. First I have to satisfy the wife and finish taking wallpaper down in the baby-to-be's room.
Old Apr 12, 2015 | 12:27 PM
Connecticut Calvin
All valves appear fine and aren't stuck. It took a while but oil is now circulating at the rockers. All good things. But man do I have one horrible driver side knock. That's the same side I have low compression too. Thoughts on this?
