Here Goes Nuthin! AC install
Old 06-20-2015, 10:48 PM
GRoper's Avatar
GRoper
GRoper is offline
Originally Posted by orich
One problem, I noticed is your fan is not far enough inside your fan shroud to get better pull of air through the condenser and radiator.
I don't know if you blocked off around the edges of your condenser for a good air flow pull through it. Best with some ac foam or other rubber shielding that can be used.
And if you mounted the condenser close within 3/8" to the radiator for good pull of air.
That will all help with your systems max cooling in city stop & go driving.
Orich
The condenser is mounted about 1/2" away from the radiator. I'll look into some foam and spacing the fan a little further onto the shroud. I do have a spacer that I took off my mustang when I pulled the pulley to put on the truck now that you mention. thanks for the advice!
  #107
Old 06-21-2015, 08:27 AM
orich's Avatar
orich
orich is offline
I've seen some fan snout spacers about 2" in length that move your fan forward into a much better area to get max air pull.
Happy motoring throughout the hot Coachella Valley
Orich
  #108
Old 06-22-2015, 10:02 AM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
How many blades on your fan? Mine has 7 and no clutch, so it moves tons of air.
Baja
  #109
Old 06-22-2015, 11:19 PM
GRoper's Avatar
GRoper
GRoper is offline
I'm not sure how many blades but its a clutch. And as orich pointed out I need a fan spacer to get it into the shroud better. I'm gonna do that tomorrow.
  #110
Old 06-23-2015, 08:43 AM
orich's Avatar
orich
orich is offline
I don't remember if, I'd said this before but not all fan clutches are the same.
As theirs one just for having AC an one for non ac.
The non ac one have more of the free spin at idling and is thermally control and engage as radiator heat goes up. .
Where as the AC clutch is more like always engaged having for better cooling,
at idling or for the slower city driving..
Orich
Ruckin69
08-22-2021 09:32 AM
Ruckin69
09-25-2018 12:16 PM
69 f-100 aman
02-24-2015 04:42 PM
fabmandelux
Oregon Chapter
18
08-22-2011 09:09 PM
esauls09
06-22-2010 10:26 PM
Quick Reply: Here Goes Nuthin! AC install
