Replacement Thermactor Line?
Old Apr 7, 2015 | 10:26 PM
jmb2011's Avatar
jmb2011
Question Replacement Thermactor Line?
So i was working on my f150 today, and replacing my valve cover gasket, and such. After i got it all back together, the green plastic line running from my EGR valve to the thermactor on the rear valve cover, snapped in two. Brittle from age i guess.
Any idea on where, or what type of hose to use to replace it? it is so tiny in size so i don't know where to begin to look. Especially after my google searches haven't turned up much at all..
Ideas?
Old Apr 7, 2015 | 11:47 PM
Torky2's Avatar
Torky2
Sounds like you are describing a plastic vacuum hard line. Check your local parts store in the "Help" area for hardline. Comes as a roll of a few feet (don't remember exactly how long), in black only. Can use short lengths of rubber vac hose that fit the hardline's OD as connectors if need be.
Old Apr 8, 2015 | 01:28 PM
1986F150six's Avatar
1986F150six
You can also replace the entire line with rubber! With the age of our trucks, it is not a bad idea to replace all of the plastic or rubber vacuum hoses.
Old Apr 9, 2015 | 10:38 AM
AbandonedBronco's Avatar
AbandonedBronco
x2!
All of my plastic lines were intact and I noticed a HUGE difference when I upgraded everything to new, soft rubber lines. Those lines get hairline cracks in them that add up to big leaks that you can't see.
If you want to keep the color coding, get some packs of colored zip ties and match the colors at both ends.
Either way, don't go through the work of replacing the plastic lines with plastic lines. It won't really gain you anything.
Old Apr 9, 2015 | 11:13 AM
Harte3's Avatar
Harte3
What they said X3!
Old Apr 9, 2015 | 06:07 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
It's expensive but silicone hose > rubber.
87oldtimer
Jun 3, 2014 06:02 PM
iilijah
1997 - 2003 F150
Dec 25, 2010 05:18 AM
vancouver island
13
Nov 10, 2009 05:45 PM
fcarruth
1978 - 1996 Big Bronco
Dec 13, 2002 06:37 PM
madman666
Oct 7, 2002 08:37 PM
