I have some random free stuff I wanted to see if anyone wants before I throw them away. I would ask that you cover shipping though. You can just send me a check after you receive your item. Here's what I have:
These are both 49 4-speed transmissions. I am PARTING them out. I'll pull off whatever you want as long as it's not the case. Just let me know what part you want. One is off an F2 (left) and the other is an F1 (right).
Parking brake parts.
Random seals.
Headlight bezel
Speedo cable. It spins freely,but looks to be missing the square inner part on the one side.
PM me if you are interested.
I also have a 4-speed hogshead and other items in the for sale section.
Do you know if the speedo cable will work on my 55? I saw that mine is disconnected(but there) so I assume it is broken.
Thanks
P.S. I couldn't find how to pm you.
It's likely that it would, but you'd have to check into it a bit. Like I said it seems broken,so it might only be good for parts. As for the PM, I think you need a certain amount of posts maybe 25? I know I read it somewhere. Once you have enough you can just click on a persons profile and then the link that says send private message. Good luck!
Just bumping this back up. I still have everything listed and don't want to throw anything away until I know that nobody needs it. I will be moving a couple thousand miles here soon and need to thin out some stuff. Again I will pull anything out or off of the transmissions and you'll only pay shipping.
Emu,
It looks like I can cram it all into a medium flat rate box (which is normally the cheapest/fastest way to ship from AK) and that would be like $12.95 if memory serves. I can also slow boat it and maybe save a couple bucks, but it normally works out to be about the same. Shoot me a PM with your address if you are interested.
Also, the brake parts are spoken for. Bob, they're on their way, enjoy!
Great to hear Bob,enjoy! Funny thing is that I forgot I had those and ended up tracking down some off an old Bronco just to uncover these shortly after.....
Emu, your seals and bezel are on their way.
Nobody needs anything from the ole crash boxes........?
