Stumped on rear end clunk
Old Apr 5, 2015 | 12:48 PM
dieselbogging's Avatar
dieselbogging
So i have this clunk in the rear of my truck. I only feel it at a stop light. If I come to a stop hard enough that you feel the suspension move and stop, you will feel a clunk. Then when i take off again and put a little more power to the wheels it clunks hard.
Ive checked and greased the slip joint with no change.
Next i grabbed the rear wheel and started rocking the truck and right away i notice the overload spring to be slapping its bumper.
It's only the driver's side doing it. Looking at the overload spring it appears to be closer to it's bumper than the other side by a couple inches. First thought was i must have bad bushings or a broken spring. I checked the whole suspension system from top to bottom in the rear. I can't find any wear or damage.
Plan on lifting it up and putting jack stands under the frame to hang everything.
What are your thoughts?
Old Apr 5, 2015 | 01:14 PM
KIDkiser's Avatar
KIDkiser
Sounds like a broke Spring or two to me.
Old Apr 5, 2015 | 01:37 PM
Tarheelldo's Avatar
Tarheelldo
Is it the rear sway bar?
Old Apr 5, 2015 | 01:42 PM
dieselbogging
I couldnt see any cracked springs anywhere and there is no sway bar in the rear.
Old Apr 5, 2015 | 01:47 PM
Tarheelldo's Avatar
Tarheelldo
You still may have found your problem. Your ability to move the suspension as compared to when we drive it can really change the outcome.
I have used this several times.... but if you have or can get a go pro cam, tie it down back there and ride a round and see if you can visually catch what its doing. I used this to diagnose two rear drive shaft issues at the diff. Just a thought! Good luck
Old Apr 5, 2015 | 02:02 PM
dieselbogging
Damn thats a good idea! Those suckers are pricey but i know who has one. I'll be seeing him in a couple days.
Old Apr 5, 2015 | 05:35 PM
KIDkiser's Avatar
KIDkiser
Still sounds like a spring problem to me.did you take the wheel off and look between the U-bolts at the spring?
Old Apr 5, 2015 | 06:36 PM
Tarheelldo's Avatar
Tarheelldo
It may very well be a spring/u-bolt that's fractured and hidden. Really hard to diagnose that without you unbolting the ubolts and separating the spring pack to QA the leafs, pins, etc....
Good luck bro
Old Apr 5, 2015 | 07:07 PM
LiftedBlackHD's Avatar
LiftedBlackHD
Id bet your leaf spring hanger is broken.
Rintin69
Feb 7, 2023 05:03 AM
Fraalan
Jul 7, 2014 12:16 PM
skoveng
Jul 4, 2013 01:16 PM
octaneforce
Dec 19, 2011 05:27 PM
Chopper_WSP
Apr 7, 2007 07:45 PM
