short to ground
Old Apr 5, 2015 | 06:21 AM
ethiele74's Avatar
ethiele74
short to ground
so as i was driving home from work the check light came on pulled codes and got all the injectors short to ground and another for the ficm well check the ficm volt key on 48 v never dropped below 47 during cranking or running. its a 07 f250 2 wheel deal 6.0 with 119000 on it just wondering where to go from hear pull the harness or what.and there has been no loss of power working on the striction problem on the next oil change other than that its a beast.
Old Apr 5, 2015 | 06:56 AM
mustang_309's Avatar
mustang_309
The specific codes would help but it sounds like your FICM is going south, the best place to get it repaired is at www.FICMrepair.com Ed does an outstanding job of fixing FICM's.
Old Apr 5, 2015 | 07:43 AM
ethiele74's Avatar
ethiele74
are there any other tests that i can do on ficm. Everything i have read if you get a mim of 48 key on and over 45 when running than its all good. so now what
and the batteries test out good as well
Old Apr 5, 2015 | 07:59 AM
mustang_309
The FICM can still be bad with 48 volts that is why specific codes would help but to have all 8 injectors throw codes makes the FICM suspect.
Old Apr 5, 2015 | 08:07 AM
Rusty Axlerod's Avatar
Rusty Axlerod
The FICM has two circuit boards inside, one is the power board, it's an amplifier that raises the battery voltage to 48v. The other is the logic side, it has a "chip" that talks/listens to the PCM and decides if, when, and for how long to apply the power supplied by the power board to the injectors. Because of the heat generated by the power board, especially if there a battery or charging system problem causing input voltage to be low, it is much more likely to fail than the logic board but the logic boards can and do fail sometimes with a perfectly good power board.
I was watching someting the other day and the presentor said you could sort of think of the FICM as the distributor in an old gasser. The logic side is like the points and point cam, rotor and cap, while the power side is like the coil and capacitor.
Old Apr 5, 2015 | 08:41 AM
ethiele74's Avatar
ethiele74
ok so i had to find where i wrote down the codes here they are po 261,264,267,270,273,276,279,282,611 b 135 and u1900
Old Apr 5, 2015 | 09:12 AM
78fordman's Avatar
78fordman
Time for a ficm, the voltage is getting low at some point. My brothers truck came up with 3 high circuit codes a while back. We pulled the ficm and ohmed the wiring harness and it checked out fine, spool valves ohmed the same as the rest. The logic side of the ficm capped out. Ed at ficm repair.com got it fixed. He had the 3 high circuit codes and a 0611. The 0611 is pretty much a dead ficm.
jmaskew
Aug 21, 2011 05:47 AM
bigbadwolfe
24
Jun 13, 2007 07:32 PM
blrman1962
May 27, 2007 11:10 AM
BigGreenGiant
Jun 28, 2006 05:27 AM
mike L
Sep 21, 2004 02:59 PM
