Sponsored by: Innova
multi meter testing...
Old Jul 25, 2003 | 06:08 PM
optikal illushun's Avatar
optikal illushun
how can i test my amp to see how many watts its puttin out and how many ohms, etc...with a multi meter? i wanna see if its a goner or not...and what other test can i do with a multi meter on a car system??
Old Jul 25, 2003 | 08:22 PM
luvdeftonz's Avatar
luvdeftonz
A multimeter will not measure how many watts (rms or otherwise) your amp puts out. It will measure voltage, resistance, inductance, and capacitance, though. You can use it to troubleshoot most amp problems and use it to set the gains on your amp. I think JL actually has a tutorial on how to use a DMM to set the gains on their amps.
I believe you need a O-scope and a steady, consistent power supply to accurately measure watts and watts rms. O-scopes aren't exactly cheap. It might be best to go to a local shop (w/MECP certified installers)...they might have one, but they will probably charge you to have your amp tested.
Old Jul 25, 2003 | 08:36 PM
luvdeftonz's Avatar
luvdeftonz
BTW, ^^^^there are a few other ways to measure the watts/watts rms, but they get even more expensive. Throw in a sound wave generator and a highly regulated power supply (say, a 200 amp DC power supply $$$$$$$$$$$) and that spells empty bank account and "heavy" credit card use....oooh!
Old Jul 25, 2003 | 11:02 PM
smokey6309028's Avatar
smokey6309028
Im sure you know this already, but you can check the resistance of the load being given to your amp with the ohm meter on the DMM. You could also check your DC Voltage going into the amp. For amp that arent regulated, the higher the voltage the more power your amp will put out.
Old Jul 26, 2003 | 12:10 AM
optikal illushun
well...i guess i cant really test it myself...i chased it down to the amp itself. i changed both set of RCA plugs and still is messed up. problem is when i turn it on, sometimes i'll need to turn the volume up to get the other speakers to "turn on"...its a jensen 4 channel "400 W" amp thats been used and abused since i bought it, i ran it to 1 ohms a few times and i dont even know what happened with the previous owned (bought used from $50)...i guess its time to get another one...o well =D
Old Jul 26, 2003 | 10:09 AM
smokey6309028
Sounds like an internal short/grounding problem. Looks like your right about needing a new amp =\
Old Jul 28, 2003 | 10:10 PM
optikal illushun
figured out what the problem is, the A channel is "blown". it is quieter then the other channels (gains set at 0 on all channel)...maye ill take it apart and see if its a blown resistor or something, any advice?
PS: i have my fronts running off channel C/D and rears ran off channel B ran to 2 ohms till i either fix it or get the $$ for a new amp...
trike1946
General Automotive Discussion
Aug 21, 2014 11:00 PM
kornfanjoe
Oct 21, 2013 07:26 AM
excoelis
Electrical Systems/Wiring
Feb 5, 2012 12:33 AM
FORD E-150
Jul 21, 2009 05:59 PM
horsepuller
Jul 27, 2003 12:17 PM
