Rear end question
Old Apr 2, 2015 | 03:08 AM
88/90f-250IDI's Avatar
88/90f-250IDI
Rear end question
Hello all. I have a 90 f-250 that currently has 4.10 gears on a 4 speed tranny. Top speed on my truck is about 45 miles an hour without really making her work. I bought a parts truck a few months ago and plan on doing a swap on the front and rear end. The gear ratio on the parts truck is 3.55. I don't really know a lot about rear end gears but I do know that the 4.10's wont work for this project to be a daily driver, but I am not sure if going to the 3.55 would take away to much to keep it from pulling what I need to pull. All I really pull with it is my 10,000 lb 5th wheel camper. Any advise will help. THX.
Old Apr 2, 2015 | 04:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
if your top speed is only 45 mph, something is seriously wrong. my 88 no overdrive with 4.10 gears has a top speed of 80 mph.
is the truck a 4 wheel drive?
with a top speed of 45 mph, i bet the transfer case in in low gear.
Old Apr 2, 2015 | 06:11 AM
88/90f-250IDI
i had thought the same thing. I may have a low gear in the transfer case, but if I put the truck in 4 lo I can tell that its in 4 lo. It definitely makes a change on the gear ratio when I have it in. Is it possible that someone changed the gearing in the t-case.
Old Apr 2, 2015 | 10:30 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
my f450 w/5.13 has a much higher top speed than 45 mph.i dunno how fast it could go but i don't think it would struggle at hwy speeds of 65/70 here.she'd be screaming sure and getting horrible economy but could do it.i keep her around 45-50.edit,but yeah i do have od though,but still.somethings up with yours.
whats happening exactly at 45 mph? do you have a tach in the truck?
and no,i wouldn't swap in 3.55's in an idi truck for a 10k lb 5ver.especially if your n/a.
Old Apr 2, 2015 | 12:09 PM
Phy's Avatar
Phy
Yeah, with 4.10s in top gear, you should be around 2800 rpm at about 65 mph.
Old Apr 2, 2015 | 04:06 PM
Coutu's Avatar
Coutu
A 4x4 7.3 5-speed with 4.10's will do 65 at about 2300-2400 RPM unloaded
Old Apr 2, 2015 | 04:26 PM
tjc transport
i ain't rite
but with a 4 speed or a C-6 trans it will be up closer to 2800 at 65.
with the 37 inch tires, i will top out at 81 mph at 3400 rpm.
Old Apr 2, 2015 | 08:06 PM
Coutu's Avatar
Coutu
Ahh I forgot he had a 4-speed, I assumed a ZF-5
Old Apr 2, 2015 | 08:13 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I don't want to insult you 89/90, but are you sure you aren't driving a 5 speed tranny in 4th gear? it was available that year, and it would help explain your gearing issue. At what rpm are you hitting 45 mph?
Old Apr 3, 2015 | 01:53 PM
EYEDEYE's Avatar
EYEDEYE
My 4X4 7.3 with a 4.10 and the E4OD will do 65 at around 2100.
Old Apr 4, 2015 | 02:57 PM
Coutu's Avatar
Coutu
You got bigger than stock tires? Either that or the E4OD is geared a bit different than the ZF-5 which is possible
Old Apr 4, 2015 | 03:03 PM
FORDF250HDXLT
very close to the same,but the E40D does have a slightly taller OD gear, making it #1 economy trans to own for hwy driving with just a whisker lower rpms than that of the zf5 trucks.
i don't like to brag about this,but i like to brag about it but get this; i once pulled in 17 mpg @ 55 mph with chip truck running a whole tank down I95.an 8200 lb DRW,4x4,enclosed box truck with the 7.3l/E4OD combo.
wanna see a pic of her? well of course you do lol!
Old Apr 4, 2015 | 04:00 PM
EYEDEYE's Avatar
EYEDEYE
Nope. Running the stock LT235/85R16.
Old Apr 4, 2015 | 07:02 PM
Coutu's Avatar
Coutu
Well, more power to ya! Like he said, it must be the taller OD than the ZF
Old Apr 4, 2015 | 07:03 PM
Coutu's Avatar
Coutu
What an ugly OBS truck...
