Mornin all From what I'm told After my wot burnout the other day I must have sucked a oring or part of my intake gasket it to motor It misses at idle and at speed .And is throwing PO174 lean bank 2 . All cops new Ford , new stock plugs , fuel filter, iat sensor .when I shut it off u can hear a big rush of air either being sucked in or blow out has anybody ever ran into these symptoms ? Thanks in advance Butch
Supercharger to upper intake gasket...1L3Z9H486BA.
Upper intake to charge air cooler gasket...1L3Z9M436AA.
Upper intake to lower intake gasket..........1L3Z9461BA.
SPECIAL NOTE HERE. If removing the charge air cooler FORD says, and I quote, "Note: When replacing or separating this piece from the manifold, the 11 N606500S100 bolts must be replaced-NO EXCEPTIONS.
Cool thanks for part numbers I'm gonna go ahead and plug the elbow in back of intake and put a oil separator in while it's apart and be done with it
