COOLANT LEAK
Old Mar 31, 2015 | 11:54 AM
WRABER's Avatar
WRABER
COOLANT LEAK
Stopped after a hard pull and noticed I had coolant dripping off the front sensor on the Brake Master cylinder. Coolant level was down in the Degas bottle. Searched everywhere for the source of the leak, and couldn't see anything. Today the drip had stopped, but when I squeezed the rear heater return hose under the Degas bottle it appeared to have a wet spot form. I'm thinking I have a very tiny pin hole, and plan on pressurizing the system to see if I can determine for sure this is where it is. Before I do though, any other ideas where this high pressure leak might be coming from? Degas bottle and cap is less than a year old. Doesn't appear to be any signs of leaks around the clamps. That rear heater hose is PITA and $70 at the dealer.
Old Mar 31, 2015 | 12:52 PM
npccpartsman's Avatar
npccpartsman
Many time that rear heater hose will rub on the corner of the FICM and leak. It's actually pretty common.
steve2003
1997 - 2003 F150
Oct 15, 2018 08:08 PM
lupuseven
Nov 3, 2013 09:23 PM
jwylie2125
Nov 26, 2012 04:53 PM
redfish67
1997 - 2003 F150
May 25, 2011 10:17 PM
BernMidwest
Apr 13, 2011 04:14 PM
