Last winter, shortly after buying my truck, I bought and installed a front receiver on my 08 Crew Cab Gasser. A buddy of mine noticed it the other day and asked what I used it for. While I was explaining it to him, I came to the realization that I haven't had the death wobble once since I installed it.
I had experienced it maybe three times in the first 500 miles that I had the truck, but after installing the hitch I have driven a 2300 mile trip and probably another 600 miles since then and haven't had it happen once.
I understand what the death wobble is and what causes it and what corrects it. I am not sure how installing a bracket around the front of the frame could correct it, but it sure seems to have changed something. I have made no changes to the suspension or tires or wheels. I also know that my rear shocks are shot, so the fronts are probable due for a replacement too.
Maybe you are on to something, I can imagine stiffening up the frame may have taken just enough flex out to make a difference.
Now that I think about the videos I have seen of a truck experiencing death wobble you can see how violently the front bumper is shaking, adding the bracket to the front of the frame added some rigidity.....reducing its ability to oscillate.
Makes sense in theory , and seems to have proven out in your case.
Could be a cure but I wonder if bolting a receiver really had something to do with the wobble. Since the receiver bolts to the frame, do you really think the frame flexes during the wobble?
I had a couple of wobbles on my '72 E-300.
I hit a small access cover in the street, at 35 mph and my right front wheel went nuts.
I attributed it to the wheel bearing but I never was sure.
I attached a front receiver, as well, but don't know if that had any effect.
You might be on to something. I to suspected frame flex and durameter of the shock and other chassis bushings as being the leading cause of the death wobble.
One video I saw shows a shock/stabilizer accelerated wear test and you can see the bushings loosing their rigidity turning to silly putty.
My Conclusion: death wobble is likely a cumulative problem in series or in parallel or series/parallel where as a few combinations of parts (more than just one combination) in conjunction with frame flex and wear all line up together to cause the problem (planetary alignment if you will).
Whereas if the frame was initially stiffer up front the problem would be less likely to occur or would occur later in the life cycle of the truck. The factory would be less likely to discover this when endurance testing as I doubt they have accelerated testing on the truck chassis as an assembly with body mounted etc...add to the fact that the right combination of circumstances need to be aligned. Thats why some trucks have it some do not. BUT you'd figure by now with all the data collected we have an engineered fix available. Time for the after market to step up with something.
I had this happen to me with a construction truck - 1996 F250 4 X 4 with a diesel engine. I just pulled on the freeway and it started to shake and wobble in the front end. Upon closer look I saw the 2 front tires were worn out. A short time after that I went through a dip and the rt side tie rod end fell apart. Replaced all the steering tie roads and tie rod ends and never had the 'wobble' problem again. The wobble experience is not a good feeling. So, was it tires or loose steering components. The 1996 PU had the independent front end with lots of wear points. I don't think the from receiver trick is the answer. My next 2 trucks were/are a 2002 and 2013 with the solid front axle - 4 X 4 with diesel engines. No problems.
