What is it?
Old Mar 29, 2015 | 02:29 PM
64rednwhite's Avatar
64rednwhite
What is it?
I changed my oil yesterday and swapped out the oil pan gasket to fix a leak and found this in the pan. Any thoughts on what it is?
Old Mar 29, 2015 | 04:28 PM
The Masked Rider's Avatar
The Masked Rider
muffler bearing for the space shuttle exhaust... ?
Old Mar 29, 2015 | 05:44 PM
yankbs 66f100's Avatar
yankbs 66f100
Come on now, everybody knows this is a muffler bearing.
Theres an old story behind this one.
Old Mar 29, 2015 | 06:18 PM
tinman52's Avatar
tinman52
Welder User
What engine?
Old Mar 29, 2015 | 07:12 PM
64rednwhite
I always forget to list the truck specs! It's a 1964 F100, 223 strait 6, 4 on the floor. I cleaned off all the oil and the top side has a polished section about 3/4 of an inch in the middle. Hmmm...
Old Mar 30, 2015 | 09:06 PM
64rednwhite
Any of you pro's recognize this part?
Old Mar 30, 2015 | 10:43 PM
Pickupmanx2's Avatar
Pickupmanx2
It's a part that yer dang lucky it stayed low!! Really, I have no clue,,, trying to picture every engine underside I've had apart,,, I gots nuthin! Although, I do think it is close to where the muffler bearings bolt up,,, you know, by the flux capacitor!
Old Mar 30, 2015 | 11:20 PM
85e150's Avatar
85e150
Possibly part of a bracket to hold the oil pickup tube. Did you inspect that while you were in there?
Is the lifter gallery open enough to drop this through to the pan? Could be some kind of tool to pull lifters. (extreme wag on that one)
Old Mar 30, 2015 | 11:49 PM
Buzz44's Avatar
Buzz44
Did you ask this same question down in the motors and engines forums?
Old Mar 31, 2015 | 08:06 AM
hiball3985's Avatar
hiball3985
I have never seen a part like that on a 223 and I've built a few over the years. There is no way to drop anything in the pan from above, the only possible way would be through the fuel pump hole. Very strange...
Old Mar 31, 2015 | 10:07 AM
Jdeshler's Avatar
Jdeshler
When I first saw it emergency brake linkage come to mind..
Old Mar 31, 2015 | 10:09 AM
64rednwhite
Well, I'm not too worried as my truck runs fine, just more curious I guess. Ironically, I changed the oil in my motorcycle and found a mystery part there too but that's a story for another forum...
Old Mar 31, 2015 | 11:09 AM
Jdeshler's Avatar
Jdeshler
Yeah I wouldn't loose sleep over it, it aparantly isn't an essential part
850BOB
6.7L Power Stroke Diesel
15
May 8, 2021 04:49 PM
Capt. Mike 1951
6.4L Power Stroke Diesel
May 5, 2017 12:18 PM
Ersatzjack
1947 and Older Ford Trucks
Feb 22, 2015 10:27 PM
djmichael24951
May 15, 2013 06:50 PM
king121893
51
Feb 15, 2008 03:56 PM
