Thud problem solved!!
Old Jul 28, 2003 | 03:05 PM
Fordguy's Avatar
Fordguy
Cool....I'll try that. Wierd thing is that it is not consistant and can occur if I have shut the motor off and then jumped back in a started it 5 min later.
Thanks for the help yall
Mark
Old Jul 28, 2003 | 08:46 PM
tbird's Avatar
tbird
Thanks Oneof6. That is exactly what mine does. Very noticable on a hill.
Old Jul 28, 2003 | 08:55 PM
hodgekuter's Avatar
hodgekuter
Talking Thud problem solved!!
I had the "thud" at early mileage (2500) . I took a pair of cutters and snipped the clip from the boot at mid support, stuck the greasegun in the boot and filled it up. Redid the boot with nylon cable ties (good ones), massaged the boot to force grease around and into splines, all went well for 57000 more miles and I did again. All is good again. Cheap fix in no time.
Bill in KY
LUV MY PSD.
Old Jul 29, 2003 | 08:49 AM
neff2k's Avatar
neff2k
Do this now before you end up doing what I had to. My truck is in the shop right now getting a new Carrier Bearing and drive shaft. The spline got messed up and binded (Did not move in and out anymore) in turn taking out the carrier bearing. Not a cheap fix for what could have been saved with a few ounces of grease!
Old Jul 29, 2003 | 12:18 PM
Fordguy's Avatar
Fordguy
Mine thud is while motionless though.
Old Jul 29, 2003 | 02:10 PM
bcmmdl's Avatar
bcmmdl
Fordguy, I have come to the carefull, well thought out, conclusion that your truck is possessed by chevy demons.
Old Jul 29, 2003 | 06:59 PM
Fordguy's Avatar
Fordguy
Thats what I think as well. I have to park between two of them everyday....I think that mine makes them feel small and weak so the only thing they can do is make my life's drive interesting as they cannot beat me. hahahaha
Old Aug 3, 2003 | 09:57 PM
tbird's Avatar
tbird
Thanks everybody. Got under the truck this weekend and took off the front clamp. Used a grease gun an filled the rubber boot full of grease, it worked and only took about ten minutes.
Old Aug 10, 2003 | 12:55 AM
ehagerty's Avatar
ehagerty
Hey guys, can someone tell me what the torque value is on the u-joint bolts?
Am also looking for a cheap manual on cd
Thanks
Old Aug 10, 2003 | 04:48 AM
ubon's Avatar
ubon
Hey guys, thanks for the info, I got the same noise in my truck, only have 30,000 miles on it. delership thinks its the tranny, I tow a fifthwheel with with no problems, shifts fine and I keep tranny fluid changed every 15k.
Thanks
John in Tampa
Old Aug 10, 2003 | 09:52 AM
tbird's Avatar
tbird
Hey Ubon, I pull a 30' trailer everyday. Like I said above I just filled the rubber boot with grease and moved it around. Try this first. I took my last truck, a 99 to the dealer and they replaced the rear springs, that didn't do anything, they then replaced my rear ujoint, which solved the problem. I have a feeling that when they re-installed the driveshaft the greased the splines which was really the cause of the noise. Go for it.
Old Aug 10, 2003 | 07:36 PM
ubon's Avatar
ubon
Thanks tbird, I'll give it a try.
John in Tampa
bconstiner
1983 - 2012 Ranger & B-Series
Dec 29, 2012 09:37 AM
Vork23
1997 - 2003 F150
Mar 20, 2011 05:40 PM
aristocraft
17
Feb 25, 2010 10:33 AM
StylinGirl
Mar 25, 2005 01:55 PM
frydaddy56
Sep 24, 2004 09:08 PM
