96 7.3
Old Mar 29, 2015 | 02:16 AM
Guy73's Avatar
Guy73
I have a 96 7.3 that I just bought after setting for a year. I had to have the PCM repaired due to it have a short. Got the new rebuilt PCM back in and got it to fire and start. It ran at idle for about 3 minutes and died like you turned off the key and now the wait to start light stays on very dim and stays on. Number 9 fuse blows. I checked the PCM and it's fine. It's did this once before with the PCM shorted before I sent it off to get it rebuilt. I know there's a short but where to start looking????
Old Mar 29, 2015 | 09:44 AM
sean9049's Avatar
sean9049
id start by checking to see if anything in the wiring harness has been tampered with, anything has been bolted/screwed into anywhere in the truck that wasnt factory, look at the wires going into your pcm, stuff like that. Good Luck and Welcome to FTE...got any pics?
Old Mar 30, 2015 | 05:11 AM
Guy73's Avatar
Guy73
I got it. It was the transmission harness that was causing the short. A wiring had wearn thru and was shorting on top of the tail shaft. Taped it up and a piece of rubber hose to insulate it and put the fuse back in and she started right up.
Old Mar 30, 2015 | 09:36 AM
oldbird1965's Avatar
oldbird1965
Good to hear!
Old Mar 30, 2015 | 09:57 AM
richdawg's Avatar
richdawg
Difficult problem solved with your very first post
Welcome to FTE
kfowler.98
Jul 22, 2017 11:14 PM
BigBlackF-250
Oct 15, 2015 06:56 PM
duggyb
Jan 24, 2014 07:17 PM
bigbubba87
24
Oct 30, 2011 06:24 PM
joshinthe586
Mar 26, 2011 10:47 AM
