Carbed engine Idle
Old Jul 25, 2003 | 10:58 AM
Trubl4U83's Avatar
Trubl4U83
Angry Carbed engine Idle
ok i have an '84 Ford F-150 V6 and it's carbeurated. well i got a tune up and the mechanic said he tweaked the carb so it wouldn't idle so high. well he set it too low i guess cause now it idle up to 0 and it dies if the gas isn't bein pushed. so if you could, help me.
Old Jul 25, 2003 | 12:59 PM
Franklin2's Avatar
Franklin2
Carbed engine Idle
I am assuming you meant an inline 6? Get somebody in the truck to keep it running, and see if you have a large round solenoid that is acting as a throttle stop. You can tell, by when the person in the truck takes their foot off the gas, the throttle arm will rest against the bolt that comes out of the solenoid. Make this solenoid bolt longer to raise the idle speed. If you don't have the solenoid, then there should be a screw down on the side of the carb you can adjust.
Old Jul 25, 2003 | 01:21 PM
gavin's Avatar
gavin
Carbed engine Idle
actually, I'd be taking it back to the shop that 'adjusted' the carb, and have them correct the problem. No sense you burning your time to correct their mistake.
