TCI mustang 2 in 1950 f1 question
Old 03-27-2015, 03:15 PM
boehmtrent's Avatar
boehmtrent
boehmtrent is offline
Need to replace the coil springs in 1950 F1. It's a TCI mustang 2 front end, and I'm getting nowhere from tci.
Can't find jack with the part number either.
Has anyone else had to buy new springs? If so where and what? It's the coil spring setup, not coil over. If I could just get a size I'd start there, these were cut an unknown amount. All I know is 375lb rating.
Thanks in advance
Old 03-28-2015, 09:26 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Thanks in advance
Unless you're running a big block the 375lb springs sound about right for your truck. Problem is, the spring rate is higher now because the spring has been shortened by an unknown amount. If it were me I'd get a new pair of the 375lb springs and go from there.
Old 03-28-2015, 10:36 AM
AXracer's Avatar
AXracer
AXracer is offline
I'd suggest giving Eaton Springs a call (they are an FTE sponsor) and tell them about your truck and what you want it to be in the end, then let them suggest the best spring choice for you. If it's not a spring they stock, they will wind a set just for you.
Old 03-29-2015, 01:53 PM
boehmtrent's Avatar
boehmtrent
Found some 375lb springs that I think will work. I think they are 13.5", I'll double check and update when I get them. Won't get here till Thursday though.
Side note...never heard anything from tci. Called three times no help. Left voicemail with tech support (aka Anthony) and no callback. Kinda surprising from them
Old 03-29-2015, 02:10 PM
MSgtling's Avatar
MSgtling
MSgtling is offline
<table border="0" cellspacing="10" cellpadding="0"><tbody><tr><td>These should be your springs from zigs: Zig's Street Rod - Catalog
</td><td>
</td><td>
<table border="0" cellspacing="10" cellpadding="0"><tbody><tr><td>BAX-8542</td><td>Springs</td><td>$69.00</td></tr></tbody></table>
vroc4507
03-12-2016 02:33 AM
just-n-time
18
06-07-2008 07:59 PM
mechanicsburg
06-23-2005 01:55 PM
Quick Reply: TCI mustang 2 in 1950 f1 question
