I just took delivery of a set of 2" drop coil springs for my 1966 F100 2WD V8. The springs are manufactured by a known company and sold through a well known parts supplier.
My question is rather simple.
I was surprised that the drop coil springs appear to be nothing more than stock springs with the top couple of coils cut off. The upper end is simply truncated as if cut with a hack saw, with the cut end sprayed with some flat black paint. With the stock springs, the upper coil is formed into a seating coil that provides almost 360 degrees of seating surface for the spring perch.
My question is whether or not this is sound spring engineering and a safe setup? The manufacturer is telling the supplier that this spring was manufactured specifically as a drop spring for this application. With drop springs being a popular modification, I would like to hear if others have purchased springs that look like the ones that I have described. My thinking is that if a new drop spring were manufactured specifically for this application, that the upper coil would be formed to look similar to the stock springs providing a good seat in the perch.
What do you guys think?
Thanks,
Mark
Not something I would put on my truck. Before I would even consider it, I would want to know the spring rate and rate of compression.
A spring is engineered to handle a specific weight. it does that by spreading the load across all it's coils. Cut a few of those coils off, and the spring will sit lower, but it will also be less able to handle the weight of the truck.
And without a propper spring seat on the end, the tip of the spring is going to be supporting most of the weight of the truck. Depending on the stringth of your spring cup, it could eventualy poke a hole in it.
Lots of people do this for show cars, and weekend hotrods, but I wouldn't do it in something I wanted to drive much.
And not really the way to properly drop the front of these twin-I beam trucks... I will venture to say it best to send 'em back and buy the drop beams. More expensive up front, but will save in the end and be more correct/safe.
Can you expound on the "right way to drop the front" statement? My thought was to try to find drop spindles and springs... I didn't know I had to get drop beams. I'd like my truck to ride like my first car - lower in the front, a bit jacked in the back. Guess I could use some help on the right process.
I haven't seen any drop spindles for a twin Ibeam. He's right, dropping the front with just springs will give you negative camber. A little is ok, but it eats tires faster. The right way to do it is with a set of dropped Ibeams. The keep the original springs and suspension geometry, so your ride is the same, but sit lower.
As for the back, there are a number of ways to jack it up. the best maybe to replace your springs with lifted. With the power these trucks make, spacer blocks are a bad Idea, unless you run ladder bars. New springs are cheeper than ladder bars.
Thanks
For these year vehicles, there are not any drop spindles that I have found yet (someone may know otherwise). To lower the twin I beam, your correct option would be to purchase AIM or DJM (or similar) beams. Reason being, there is not adjustment for camber on the solid beams other than bending them (nobody really wants to touch that). Basically the drop beams are like drop spindles, only the axle itself compensates for the drop and keeps the geometry correct.
Yes but does anyone have any other opinions about the springs that I bought? Regardless if I use them or not, I would like to know if others have seen new springs manufactured as I have described.
BTW, is Po Boys still manufacturing Drop I Beams? they always looked like stock, but dropped.
Thanks,
Mark
The springs you purchased sound like standard production type springs cut off like you drescribe and touched up. This will work, but have the previously mentioned drawbacks. Another drawback is the reduced travel to your bumpstops. Make sure they are in good shape or you will have jolting metal to metal contact. I'm running some F250 coils w/ a coil cut out. I like this better than the lower rate F100 springs which bottomed out frequently. Tire wear remains excellent and even. It's' a bit stiffer ride but mine is still a working truck.
