Constant Cycling While Running
Old Mar 27, 2015 | 02:11 PM
jafledd's Avatar
jafledd
I have a 91 F250 with the 7.3 IDI, I just replaced the glow plug controller and glow plugs. The issue I am having with it is that after properly installing the new controller and the glow plugs it cycles even when the the truck is running I can see it on the battery meter and hear it cycling. I am confused as to what it might be and tried skimming the 1000's of threads and post but cant find the same issue I am having. Any wisdom from the masses would be great. Note the controller cycles for 5-10 seconds as it should followed by the on off if you wait to long so it seems to be operating just fine in that aspect. Thanks for your time.
Old Mar 27, 2015 | 02:23 PM
bashby's Avatar
bashby
It is normal to cycle for a few seconds after it starts. Is that what it's doing or is it all the time?
Old Mar 27, 2015 | 02:34 PM
jafledd's Avatar
jafledd
long enough to smell burning wires. That is when I deiced to shut it off. At that point I ensured that the ground was good and tried it again with no change. Any ideas ?
Old Mar 27, 2015 | 03:22 PM
bashby's Avatar
bashby
I think the only thing it could be is a defective controller. Did it do the same thing with the old one?
Old Mar 27, 2015 | 04:35 PM
jafledd's Avatar
jafledd
The old one did nothing at all, think this problem might have been the reason it died so when it stops raining I will get back out there and pull it and see if there is anything out of sorts and more than likely send it back to the mfg.
Old Mar 28, 2015 | 06:04 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the coolant temp sensor is bad, it will not tell the controller the engine is warmed up and supply it constant power.
once engine temps hit 110 degrees, the coolant temp sensor tells the controller to turn the glow plugs off.
Old Mar 28, 2015 | 05:14 PM
jafledd's Avatar
jafledd
Thank you guys for the help it was the coolant sensor didn't think to check that at all I would have been looking else where thanks again.
Old Mar 28, 2015 | 05:57 PM
tjc transport
i ain't rite
CGMKCM
Dec 11, 2014 08:10 PM
ALL BOY
Jan 9, 2006 06:07 PM
79man
Dec 1, 2005 06:49 PM
Gr8ride
Sep 5, 2005 11:13 PM
fordiesel69
Apr 26, 2001 03:31 AM
