Sponsored by: Real Truck
Sputter
Old Mar 27, 2015 | 12:59 PM
Gmbchief's Avatar
Gmbchief
Sputter
Hi all. I have '99 F-250 SD with a 5.4. I can start it up just fine but after driving just a few miles it starts to sputter like its missing a cylinder. In the past I got the dummy light when s cool pack failed but no light this time. It starts off with a little sputter but in just a few minutes it get to the point where o can barely accelerate. There is also some back firing going on when it's at its worst. I had codes saying "Bank 1&2 too lean". I checked the vacuum system and found one off on back side of manifold. I fixed that, no codes but it still does the same thing. Any suggestions? Thank you
Old Mar 27, 2015 | 02:02 PM
Gangly's Avatar
Gangly
If you are getting banks 1 & 2 lean, look at fuel pressure. Check to make sure you are getting the appropriate fuel pressure for your engine. Symptoms of low fuel pressure include occasional surging, a generally smooth idle but a stumble when trying to accelerate, increased stumbling when engine under a load.
Old Mar 27, 2015 | 02:20 PM
AAubinoe's Avatar
AAubinoe
If both banks are lean it could be a failed intake gasket or cracked intake.
Old Apr 2, 2015 | 08:01 AM
PaxtonShelby's Avatar
PaxtonShelby
As said above, I'm thinking some sort of vacuum leak with those lean codes.
Old Apr 2, 2015 | 06:55 PM
Gmbchief's Avatar
Gmbchief
Thank you for all of the advice. I think you were all correct with your answers. First if found a major vacuum leak, the repair did not solve the problem. I then took the truck and drove it at around 50Mph, that's the speed it ran the worst. I drove until I finally got the check engine light. Multiple misfire, bank2 to lean & cyl 6 misfire. Replaced coil on #6, it runs better but still has a minor sputter. I believe intake might be leaking. Again, thank you.
bren_tx
1997 - 2003 F150
Sep 13, 2016 10:10 PM
crazy96863
Dec 1, 2015 09:57 PM
ray299
May 25, 2012 05:10 PM
johare
1983 - 2012 Ranger & B-Series
Mar 6, 2006 05:46 PM
truckfreak69
Oct 26, 2005 12:24 PM
