Check Engine Light
Old Oct 25, 2005 | 11:39 PM
truckfreak69's Avatar
truckfreak69
Check Engine Light
Hey I had the codes pulled and it says lean condition in both banks. What could this be? The truck hasn't seemed to change the way it's running, but the light came on.
Old Oct 26, 2005 | 06:45 AM
PSKSAM2's Avatar
PSKSAM2
Some threads of possible interest I found with a search of "lean both banks":
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-422939-DTC%200174%20and%201443%20-%20Poor%20gas%20mileage">DTC 0174 and 1443 - Poor gas mileage</a>
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-419682-97%20Ranger%20Running%20Lean%3F">97 Ranger Running Lean?</a>
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-409139-Code%20says%20running%20lean">Code says running lean</a>
Most of these are for 97 4.0's. It would help to know your truck year and engine and the exact codes.
Good Luck,
Jim
Old Oct 26, 2005 | 12:24 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Both banks lean usually means a fuel delivery problem. Low fuel pressure, bad MAF sensor, or vacuum/intake manifold leak, to name just a few. Sometimes they're obvious - a bad PCV will do it - but sometimes they're very subtle. If the fuel pressure is good and there are no other codes, I'd have the intake manifold smoke tested... Good luck.
