1978 - 1996 Big Bronco
engine swap
Old Mar 26, 2015 | 05:38 AM
smittys5xs's Avatar
smittys5xs
engine swap
I was thinking about doing an engine swap from my 351w to a 7.3 power stroke in my 1996 bronco, does anyone know if the later 7.3's (99-03) will swap over? They have more stock power and are more desirable in my eyes, if not I know an earlier engine will, but with the body change I was unsure if the same motor was put in. I'm almost certain I know the answer but thought id ask just to clarify.
Old Mar 27, 2015 | 04:01 PM
rla2005's Avatar
rla2005
Get out your wallet......is the final answer. Anything is possible with enough $$$$
Any gas to diesel swap is expensive, the later versions are even more $$$$$$$$$$$
Old Mar 27, 2015 | 06:31 PM
gatorfor88's Avatar
gatorfor88
Better off to get the idi 7.3. All mechanical not computer crap to worry about.
Old Mar 27, 2015 | 11:30 PM
newr's Avatar
newr
Front Axle Considerations
Have you checked to make sure that the stock Bronco IFS front axle will carry the weight? Part of your project could end up being a front axle swap.
Old Apr 1, 2015 | 05:29 PM
smittys5xs's Avatar
smittys5xs
I have thought about this, im thinking im going to get a salvaged truck and use it as a donor and just completely swap everything over, axles, mounts, fuel system, electrical. I might just beef some things up along the way
Old Apr 1, 2015 | 09:35 PM
newr's Avatar
newr
Nice
One of my former Ford's was an '88 F250 with the IDI 7.3. If you haven't yet you might spend some time on the IDI forum. They are a good bunch and would add value I'm sure.
Old Apr 2, 2015 | 09:18 AM
Kemicalburns's Avatar
Kemicalburns
this has been done, I believe I read about it on this forum or over on fsb.com. getting the same year donor rig as your bronco would be advised. you will want to swap pretty much everything over to the bronco. axles, trans and even the dash or at least the instrument panel. the dash's are different since the bronco has rear defrost and the window button although you could mount those if necessary.
Mikey90
Engine Swaps
Apr 26, 2015 06:14 PM
smittys5xs
Mar 26, 2015 08:01 AM
mater73
17
Apr 12, 2013 10:54 PM
johnnyrocket
Engine Swaps
Apr 23, 2009 06:50 PM
DirtySideDown
Sep 1, 2002 06:06 PM
