Low Oil Pressure Question.
Old Mar 25, 2015 | 04:46 AM
Death_Eagle_571's Avatar
Death_Eagle_571
Exclamation Low Oil Pressure Question.
Hey guys, I have the 240ci Straight-6 in my 66 F100, and Recently I had my oil changed to Shell Rotella-T 15W40, it did have 10W30 Rotella-T in it before, but the guys that did it overfilled it by one quart, so I had it drained and replaced with the 15W-40, my Owner's manual said this would be much closer to what I should be running in it for the climate I'm in. really didn't want to leave anything to chance with this engine, I want it to stay nice. Anyway, what I noticed is now the Oil pressure is sitting around 30 psi or alittle less when the engine is running, and it used to be around 55-60 psi. Any ideas whats going on here? I'm not sure what oil was in it before I changed it for the first time, all I know is it was pitch black. I'm worried this is too low for this engine.
Old Mar 25, 2015 | 09:51 AM
sseebart's Avatar
sseebart
Welcome to FTE.
There should be some fluctuation of pressure as the engine speed changes. Is that the oil pressure reading at idle or at speed?
The rule of thumb I heard from a local rebuilder is at least 10psi for every 1,000 rpms, so 30 psi at idle should be fine, but might be a little low if you're seeing that on the highway.
The sudden change is a little troubling but may have more to do with the gauge than something inside the engine.
~Steve
Old Mar 25, 2015 | 06:23 PM
Death_Eagle_571
Thanks, it stays about the same both at idle and at speed.
Old Mar 26, 2015 | 04:25 AM
jowilker's Avatar
jowilker
Your engine was designed to run straight 30w oil. Spend all the money that you want to make yourself happy on Rotella and other exotic name oils, but any 10W30 bottled recently is better than anything 50 years ago.
I think guys spend far too much time on pressure readings from old worn out equipment. If there is oil in the engine and the pressure is flexing you probably OK.
John
Old Mar 26, 2015 | 02:49 PM
Death_Eagle_571
Yeah, thats true, but I'm just really OCD about my truck staying in the best health as possible, I'm such a Ford addict hehe
Old Mar 26, 2015 | 06:18 PM
Death_Eagle_571
Ok, so it seems like its gone down slightly, I wonder if maybe the pick-up screen is clogged, if i recall correctly, it went from 55-60 down to 30, now its closer to 20..
Old Mar 26, 2015 | 06:21 PM
jowilker's Avatar
jowilker
Unless the engine is fairly new, don't sweat it. You are likely fretting over nothing.
John
Old Mar 26, 2015 | 06:33 PM
Death_Eagle_571
I'm honestly not sure, it only has around 110,000 miles on it, runs whisper quiet with no valve chatter or ticking, so I'm at a loss as to why this is happening, it just seems really strange to me that it would have that much of a drop from going to what was in it to the 15W-40, even if it was Straight 30W, I wouldn't think it would make that much of a difference...
Old Mar 27, 2015 | 02:38 AM
jowilker's Avatar
jowilker
You could have been getting a false reading before, don't know. If the oil is up on the stick, the engine is humming, it's very likely OK. Get some good music playing and drive.
John
Old Mar 27, 2015 | 03:00 AM
Death_Eagle_571
Yeah, I had another thought, if the old filter was clogged full of gunk, would it have caused a pressure reading that was much higher than what I'm getting now? And about the music - my F100 doesn't have the optional radio lol
Old Mar 27, 2015 | 08:57 AM
sseebart's Avatar
sseebart
I'd say it's worth investigating further--even just if it's for peace of mind. I'd get a cheap mechanical gauge and set it up temporarily to confirm (or not) the pressure readings you're currently getting.
Back in the day, it was pretty uncommon to see a motor reach the 100k mark. If you're at 110,000 with no rebuild, a reading of 20-30psi might be about right. As jowilker has said, if everything else is working ok (no smoke, decent power, etc) the low pressure isn't a deal killer--just don't overwork it.
~Steve
Old Mar 27, 2015 | 09:30 PM
Death_Eagle_571
Yeah, I was thinking, I wonder if the old dirty oil, coupled with a clogged filter would lead to those higher readings, then the fresh oil + filter, cleaning out the oil passages, would expose a weak oil pump.
Old Mar 28, 2015 | 10:28 AM
sseebart's Avatar
sseebart
It's possible the pump is weak, but at 110k, far more likely that wear in the bearings is causing the low pressure.
~Steve
Old Mar 28, 2015 | 03:11 PM
Death_Eagle_571
The main bearings?
Old Mar 29, 2015 | 10:38 AM
sseebart's Avatar
sseebart
Originally Posted by Death_Eagle_571
The main bearings?
Likely, and probably also cam bearings.
