What is This Parts Function
Old Mar 23, 2015 | 07:37 PM
sweetlou1's Avatar
sweetlou1
I never really knew what this was for, but is this a small oil cooler for the engine on my '72 390? It seems to be leaking motor oil.
Old Mar 23, 2015 | 08:03 PM
Behemoth's Avatar
Behemoth
I can't see where it's connected, but it looks like someone added a cooler for the power steering. Granted, that isn't a factory application, but Ford did have power steering coolers on some trucks. if you follow the inlet and outlet, and they're connected to the power steering pump on the low pressure side, that'd be my guess as to what it's for.
Old Mar 23, 2015 | 09:28 PM
HIO Silver's Avatar
HIO Silver
Correction.......That is a factory PS fluid cooler/heat exchanger. It is bent over.
Here is my one-owner, generally unmolested 71 F-250 with such a cooler.
.. and I've seen plenty of them in the salvage yards.
farmallmta's Avatar
farmallmta
That is a heat exchanger to transfer heat from working fluid to the surrounding air, usually placed in the cooling air stream ahead or behind the radiator/fan. Yours has it behind the fan. Some were installed in the automatic transmission line, too, usually in a way that road draft under the vehicle would pass through the exchanger to pull heat out of the cooling fins.
They were usually situated so that sediment and sludge would not accumulate in a low spot of the exchanger, thus the upright-ish orientation of the unit.
That's a good item to have, if properly maintained.
Last edited by farmallmta; Mar 23, 2015 at 09:29 PM. Reason: Doh! HiOSilver beat me by 3 seconds! GRRRR! ;P
Old Mar 23, 2015 | 09:31 PM
Agent 86's Avatar
Agent 86
Flux Capacitor. Be careful at 88mph.
Old Mar 23, 2015 | 10:22 PM
gangstakr's Avatar
gangstakr
Just like HIO said "That is a factory PS fluid cooler/heat exchanger" I was pulling them when I saw them in the wrecking yards. I do have a few of them. Cool item to have.
Old Mar 23, 2015 | 11:40 PM
351Cleveland C4's Avatar
351Cleveland C4
I like this one better!
Old Mar 24, 2015 | 06:57 AM
sweetlou1's Avatar
sweetlou1
Maybe that's why it seems to be leaking
Old Mar 24, 2015 | 10:12 AM
CougarJohn's Avatar
CougarJohn
All wrong. That is a macrowave antenna placed ahead of the distributor to outrun ignition interference.
Old Mar 24, 2015 | 11:24 AM
JEFFFAFA's Avatar
JEFFFAFA
Beating it to it's own interference Before it can have a miss. BRILLIANT! Kinda like IT'S Back To The Future.
Old Mar 24, 2015 | 05:53 PM
abe's Avatar
abe
Here is a picture of that 1970 F-100 (from another Bump site) with only 358 original miles on it showing the power steering fluid cooler properly installed.
The one on my 70 F-350 leaked last year and I bought one similar to it at NAPA. Had to retrofit it to get it on the bracket but it did the trick. Don't have any pics of it now but I can guarantee you it doesn't look as clean as the one above!
Old Mar 24, 2015 | 06:00 PM
JEFFFAFA's Avatar
JEFFFAFA
I see a A/C compressor mount bracket behind and below it. I believe originally that P/S cooler was bolted to the side of the compressor. Seems like I've seen that before.
Old Mar 24, 2015 | 08:37 PM
351Cleveland C4
Where on earth does a 358 mile bump truck come from??? Some guy buy it and then die?
Old Mar 24, 2015 | 08:53 PM
JWC 3's Avatar
JWC 3
Too clean ... I call B.S. . Ain't no way that is all stock . Too much detail , too good . Even stock factory fresh did not look so good .
Old Mar 24, 2015 | 08:58 PM
HIO Silver's Avatar
HIO Silver
Head over to the other website and PM the administrator.
