looking for some parts
1997 2012 Ford Econoline Van E150 E250 E350 E450 Console Cup Holder | eBay - maybe drink holders are illegal in Germany
I don't know what is a rear door light switch. Do you mean a trigger for the interior lights?
I also don't know what you are indicating with the red mark on the driver seat.
How about some telescoping tow mirrors? 03 07 Ford Econoline E Series E150 E250 Extendable Manual Tow Mirrors LH RH | eBay Also available with powered mirror control and mirror heaters.
These are not my items for sale. Just pointing out possible sources.
Sixto
93 E150 Chateau 5.8 190K miles
saw your message related to the econoline trucks.
I bought an E350 (Winnabago) recently and had some strange "jungle trips" into the wiring chaos lately. Do you have any good sources for wiring diagrams of the E350 with 7,3 PSD? I bought some books in the net but was rather dispointed by the content.
Jan-Peter
thank you very much for the fast feedback.
That did the trick. I didn't know the term "EVTM". (I am Germany ;-)
The truck is a 1994 E350 transfered into a Winnabago mobil home with 7,3 ltr Diesel.
I found this on ebay "http://www.ebay.com/itm/1994-FORD-ECONOLINE-VAN-E-150-250-350-ELECTRICAL-WIRING-EVTM-SERVICE-SHOP-MANUAL-/381178985195?vxp=mtr&hash=item58c009baebWhould that be the right thing?
Jan-Peter
There's enough room behind the door panel for the window motor. You just need to add a relay with a switched hot and always hot, otherwise you'll have the switches illuminated all the time. I can send you a write up in German if you want. Haven't made pics, but have to open the passenger door panel anyway sometime soon to change the door lock actuator.
The power locks are also universal stuff.
Seats is not as easy since there's the seat belt tensioner mounted to the stock seats and this throws a code in the airbag system when you remove it. I thought of new seats myself, but went with new seat covers instead.
Talking about parts, do you happen to have 1 or 2 of the original "dog dish" style steel hubcaps for the stock steel wheels ?
"happen to have"? sorry, didt understood the question. you want to offer me some or want to buy some?
i got 4 of them, but all needed.
what will happen when it will throw a code in the airbag system? i wanted to replace them cause they are weak...
The code in the airbag system means the airbag idiot light in the cockpit lights up and the airbags do not work anymore, so no more funny balloons in front of your face when you hit the wall
and more important, no TÜV next time.
If the seller won't sell or ship to Germany please privately message me and I could buy and send it to you for just the cost of the transactions.
and more important, no TÜV next time.- könnte dir die dinger verkaufen samt felgen...denn ich steh nicht drauf und fahre auch andere
?-so obviously not an option. some tricks to avoid this problem?
i think i will leave the seatbelt as it is and only change the chairs.
The seat belt latches and tensioner are directly mounted to the seat itself, not the seatbase, so changing the seat to anything else than a Ford seat might be mission impossible. Maybe some Mustang seats will fit.
i removed my seats before. the latches were mounted to the seat but the tensioner is not. have a look
so i think i could install a different seat an find a solution for the belt latches. may fix it on the seat base?
the following photo shows my idea of comfort. i stuffed the whole car with these anti vibration matresses (correct word?) to make it quiet while driving. the noise level decreases enorm. later will post a picture of my roof. installed maybe 40 of them ^^ also using fleece.
the dark spray is some wax against rust.
on the front floor, walls and under the headliner. The cargo floor will be herculined and get a wooden floor and the sides also get plywood decking. I also have 2 sliding windows out of a Defender to add in the rear panels.
The stock insulation under the front rubber mat stores water and leads to rust damage.
I'll get in touch with you later this week, I have to give a Raptor a run for his money for a TV show tomorrow
