Another unknown?
Old Mar 21, 2015 | 03:30 PM
trike1946's Avatar
trike1946
Question Another unknown?
Also with my 07 E350......What is the black thing above the spare tire? It is wide and a bit round with something that looks almost like an oxygen sensor in the middle. I guess I better go on ebay or craigslist and get a manual.
Oh and the button on the dash that looks like the back of a car with tire marks after it? What is it? Something to do with traction or skidding? Do I ride with it on or off?
Old Mar 21, 2015 | 07:31 PM
vettex2's Avatar
vettex2
pics please ?
Old Mar 21, 2015 | 07:53 PM
trike1946's Avatar
trike1946
I will get some in the morning.
Old Mar 21, 2015 | 08:00 PM
tabijan's Avatar
tabijan
Might the thing above the spare be the winch?
Sixto
93 E150 Chateau 5.8 190K miles
Old Mar 21, 2015 | 08:42 PM
trike1946's Avatar
trike1946
Sixto
It looks like some kind of plastic gizmo about two feet across, round in places like a bat and in the middle is a wire attached to something that looks like an oxygen sensor. Is that what the winch looks like? It is over the tire.
Old Mar 22, 2015 | 04:59 AM
Im50fast's Avatar
Im50fast
Sounds like maybe the EVAP thing.
And the dash button sounds like traction control.
Get us some pics
Old Mar 22, 2015 | 06:18 PM
trike1946's Avatar
trike1946
Ok I have some pics, but being more of a carpenter than a computer expert I can't figure out how to post them. Can somebody give me a clue?
Old Mar 22, 2015 | 06:54 PM
trike1946's Avatar
trike1946
I think this works.
Old Mar 22, 2015 | 08:28 PM
tabijan's Avatar
tabijan
That's not the winch for the spare. I can't imagine why it's so far from the fuel tank if it's related to vapor recovery but that's what I imagine it is.
The button turns OFF traction control. The OFF indicator will light when traction control is off.
Sixto
Old Mar 22, 2015 | 08:36 PM
trike1946's Avatar
trike1946
Sixto
Under normal conditions should the button be on or off?
The black thing is pretty far from the tank. The tank seems to be up towards the middle and this is by the spare and plus the van is extended.
Old Mar 23, 2015 | 02:17 AM
wiskeyVI's Avatar
wiskeyVI
Dude!, i took a pic last night of that same thing above the spare while I was trying to look for Axel id.
I was wondering what it is as well????!!!
Old Apr 17, 2015 | 06:49 PM
trike1946's Avatar
trike1946
I finally stopped at a dealer and the mechanic said it was an EVAP. Strange place for it. I thought it would be more forward.
Old Apr 18, 2015 | 05:50 AM
wiskeyVI's Avatar
wiskeyVI
EVAP
Any idea what's it supposed to do?
Old Apr 18, 2015 | 06:44 AM
JWA's Avatar
JWA
Because the fuel system operates under "high pressure" vapors that arise from the fuel could be trapped in that system which in turn could potentially create an old condition once known as "vapor lock". While that is a bit different from current fuel systems it would be the same where vapor pressure inside the sealed system could block fuel flow to the injectors.
Stored vapors in the tank and fuel lines are vented into the throttle body when the ignition system is on, typically during start up. Most have heard a burping or gurgling sound and wondered what it is.
Because its part of the seal and "high pressure" fuel system it can create problems but its pretty much maintenance free in that not a lot we can do to extend its life other than check for damage plumbing lines into and out of it. DTC's will be triggered if the PCM seem something amiss though.
HTH
Old Apr 18, 2015 | 06:55 AM
Im50fast's Avatar
Im50fast
The fuel vapors in the tank are considered harmful to the environment, so the carmakers have to control it.
The EVAP system simply contains the gasoline vapors and feeds them into the engine intake so they'll be burned (instead of quietly evaporating to the atmosphere.
