Sponsored by: Innova
2008 f350
Old Mar 21, 2015 | 01:43 PM
Slackdaddy's Avatar
Slackdaddy
2008 f350
I have searched but can not find the pinout for the 24pin radio connector for a 2008 super duty. I am looking for what pins 4,5,6, and 7 are for?
Is there a reverse signal to the radio connector??
Thanks,
Slack
Old Mar 31, 2015 | 08:05 PM
madsonp's Avatar
madsonp
#512299: 2008 FORD F350 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK/BLUE (-) RADIO HARNESS
Illumination VIOLET/GRAY (+) RADIO HARNESS
Amp Turn On VIOLET/RED (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) WHITE/BROWN
RF Speaker (+) WHITE/VIOLET
RF Speaker (-) WHITE/ORANGE
LR Speaker (+) WHITE/GREEN
LR Speaker (-) BROWN/YELLOW
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BROWN/BLUE
Steering Cntrls OPTIONAL
Radio Security YES
Security
Battery BLUE/RED (+) IGNITION SWITCH
FOR HIGH CURRENT LOAD GO TO VEHICLE BATTERY
Ignition 1 WHITE/ORANGE (+) IGNITION SWITCH
Starter 1 BLUE/WHITE (+) IGNITION SWITCH
All Door Trigger VIOLET (+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
GREEN WIRE UNDER DRIVERS SILL IN HARNESS COMING FROM PASSENGER SIDE
Domelight Super GREEN/BLUE (-) HEADLIGHT SWITCH
LF Latch GREEN/VIOLET (OPEN) IN HARNESS IN DRIVER KICKPANEL
THESE TRIGGERS REST AT (-) AND ARE OPEN WHEN THE DOOR IS OPEN
RF Latch WHITE (OPEN) IN HARNESS IN PASSENGER KICKPANEL
Parking Lights BLUE/GRAY (-) HEADLIGHT SWITCH
IF THE VEHICLE IS EQUIPPED WITH AUTO HEAD LAMPS USE MUST USE TWO RELAYS. ONE RELAY WILL GET CONNECTED TO WHITE/VIOLET(HEADLAMP OFF) THE OTHER WIRE WILL GET CONNECTED TOVIOLET/GREEN(AUTOLAMP ON). WITHOUT AUTOLAMP ONLY ONE RELAY ON HEADLAMP OFF.
Low Crr Pk Lights VIOLET/WHITE (+) DRIVERS KICKPANEL
Convenience
Headlights-Lo YELLOW/BLUE (-) HEADLIGHT SWITCH
Parking Brake WHITE/VIOLET (-) AT VEHICLE PARKING BRAKE SWITCH
Seat Mem 1 VIOLET/WHITE (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Seat Mem 2 YELLOW (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH
Accessory 2 BROWN/YELLOW (+) IGNITION SWITCH
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) STEERING COLUMN HARNESS
Tachometer BLUE (AC) AT HARNESS NEXT TO BRAKE PEDAL
SEE THE PICTURE IN DOCUMENT SECTION
Speed Sense YELLOW/BLUE (AC) AT ABS CONTROL MODULE
ALSO AT WIPER MOTOR
Low Crr. Pk Lights VIOLET/WHITE (+) DRIVERS KICKPANEL
Brake Lights VIOLET/WHITE (+) BRAKE SWITCH
Reverse Lights GREEN/BROWN (+) IN HARNESS IN DRIVER SILL PANEL
Horn YELLOW/RED (-) STEERING COLUMN HARNESS
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Door Lock Circuit 3 WIRE NEG
Power Unlock YELLOW/VIOLET (-) DRIVERS SIDE KICK PANEL
WITHOUT KEYLESS ENTRY 5 WIRE REVERSE POLARITY
PowerLock BLUE/GREEN (-) DRIVERS SIDE KICK PANEL
Driver Mtr Unlock VIOLET/GRAY (+) DRIVERS SIDE KICK PANEL
Driver Mtr Lock GRAY/BROWN (+) DRIVERS SIDE KICK PANEL
Pas Mtr Unlock BROWN/GREEN (+) UNDER PASSENGER SIDE DOOR SILL PLATE
Old Apr 3, 2015 | 10:44 AM
Slackdaddy's Avatar
Slackdaddy
thanks, that will get me started
Old Dec 27, 2015 | 04:57 PM
TimWaite's Avatar
TimWaite
Audio/Mobile Video
Radio Security YES
Security
Convenience
Remote Start
ALSO AT WIPER MOTOR
Modules
WIRE LOCATION
Doorlocks/Windows
My 09 be the same color combo?
Old Dec 27, 2015 | 10:28 PM
madsonp's Avatar
madsonp
I'm afraid this is all I could come up with for your 09. I can't honestly say the wiring on a 08 is the same as your 09. Hope this helps you.
2009 Ford F250 Car Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Violet/Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Old Dec 28, 2015 | 04:47 PM
TimWaite's Avatar
TimWaite
Thank you very much. I think it will help
usdot2
Feb 17, 2010 08:24 PM
tunnel vision
6.4L Power Stroke Diesel
Oct 29, 2008 02:32 AM
almbon
Oct 13, 2008 04:49 PM
nmssr08
Jun 19, 2008 11:41 AM
spike552
Apr 8, 2008 09:25 PM
