2006 5.4 Expedition Engine trouble
Old Mar 19, 2015 | 06:22 PM
Don Expedition's Avatar
Don Expedition
Has anyone had trouble with a 2006 5.4 expedition missing and loss of power with a P0345,P0349,P0355,P0356, and a P01290 code? it will run and pop like a backfire is going on. Please if have any thoughts please answer. Thank you
Old Mar 19, 2015 | 09:11 PM
alloro's Avatar
alloro
Cylinders 5 and 6 are not firing due to the COPs or the wires to them being no good.
Old Mar 20, 2015 | 12:42 AM
Skauber's Avatar
Skauber
I think you have had a rodent or something chewing on wires. The codes show issues with cylinder head temp sensor, camshaft sensor bank 2, primary circuits to coils on cyl 5 and 6. I highly doubt all these are going bad at the same time, so time to check the main harness and connector for the engine.
Old Mar 20, 2015 | 03:31 AM
Don Expedition
Thank you Skauber,
Any thoughts on how to test them short of an ohm meter?
Old Mar 20, 2015 | 03:51 AM
Don Expedition
Thank you Alloro
Old Mar 20, 2015 | 03:59 AM
Skauber's Avatar
Skauber
Inspect for visual damage first, then you'll need an ohmmeter to check for continuity. I have the '05 workshop manual in paper, but not in PDF (yet, have to find one...) but I think maybe Alloro has a few pdf's.. It's pretty easy to beep out the connector when you have the pinout and diagram in front of you.
Old Mar 20, 2015 | 04:22 AM
Don Expedition
Awesome, will give it a try Thanks alot.
Old Mar 20, 2015 | 04:25 AM
Don Expedition
Skauber, would it be okay to ask Alloro for this diagram?
Old Mar 20, 2015 | 09:58 AM
alloro's Avatar
alloro
He's a cranky SOB, but it couldn't hurt to try.
Actually the number of pages would be quite extensive and uploading them here would not be practical even if it was allowed.
Old Mar 20, 2015 | 10:30 AM
Don Expedition
Thanks Alloro
Old Mar 20, 2015 | 10:42 AM
Skauber's Avatar
Skauber
Alloro, if you have the pinout diagram for the PCM connectors for him, that would be the most helpful I think. Just find the pins for the affected sensors and then check the resistance between it and the connector on the sensor is all that is needed, though that cyl head temp sensor is UNDER the intake and might be a challenge to get to without removing the intake... The intake manifold will have to come off if the harness is damaged behind it, as I don't think you can get it up and over the intake in any good manner..
Old Mar 20, 2015 | 10:57 AM
alloro's Avatar
alloro
Here are the 3 ECM connectors. (2 pages per connector)
File Type: pdf
Old Mar 20, 2015 | 10:59 AM
alloro's Avatar
alloro
You have to remove the upper intake to get to the cylinder head temp sensor. There's no getting around that.
Old Mar 20, 2015 | 11:33 AM
Skauber's Avatar
Skauber
Missing page two on those diagrams..
Camshaft sensor 1 signal is on C175e pin 45
Camshaft sensor 2 signal is on C175e pin 44
Cyl head temp signal is on C175e pin 41
Sensor signal return for all is on C175e pin 58
Voltage supply for coils come from connector C270d pin 7, on fuse box behind passenger kick panel. Easiest is to check if pin 1 in the COP plugs has 12V+ when ignition is ON, and I don't think that is an issue since the other coils work.
The only common wire is the signal return wire on pin 58 for the sensors, but it doesn't have anything to do with the coils.
the coils are shown in the PDF.
Old Mar 20, 2015 | 02:05 PM
alloro's Avatar
alloro
I don't understand...I just loaded it and all 3 pages are there.
