black soot?
Old Mar 16, 2015 | 07:57 PM
fordboy300's Avatar
fordboy300
black soot?
So today I was working on the pickup. I changed the thermostat today basic maintenance. I creeped up underneath the truck to put a clamp on the lower radiator hose, and I saw that my exhaust manifold had some seapage with black wet soot. I wiped it off smelled it...didn't smell like anything to me. Not sure what it is. Any ideas? I'm using the felpro gasket set. I also didn't use any red RTV on the manifolds.
Old Mar 16, 2015 | 09:46 PM
AbandonedBronco's Avatar
AbandonedBronco
WHERE on the manifolds was this? Maybe you don't have one of the runners tightened down all the way?
You have the EFI manifolds if I remember right, don't you?
Old Mar 16, 2015 | 10:27 PM
fordboy300's Avatar
fordboy300
Yes sir EFI manifolds. It was on the bottom side of the manifolds and the wet black soot I call it was on the block too coming from the manifolds maybe they backed off a bit. I should have took a photo.
Old Mar 17, 2015 | 02:00 PM
fordboy300's Avatar
fordboy300
Here's a photo.
Old Mar 17, 2015 | 02:03 PM
AbandonedBronco
Are you talking about on the block?
That looks runs of oil from a leak to me.
Old Mar 17, 2015 | 03:07 PM
fordboy300's Avatar
fordboy300
Yeah that's what I figured too When I first saw it was real quick and then I looked at it with a flashlight this morning I was like crap it's oil! I'm guessing if it coming from the port it's oil seals?
Old Mar 17, 2015 | 03:09 PM
AbandonedBronco
Yeah, it looks like it's coming from higher up. Maybe just a bad valve cover gasket?
Old Mar 17, 2015 | 04:07 PM
fordboy300's Avatar
fordboy300
Funny you should say that because I bought one for that same reason because it is leaking on the driver side towards the back of the block. It will be cleaned up regardless next week I plan on changing the intake manifold and finally putting on the Holley 465! :-)
Old Mar 18, 2015 | 10:58 AM
AbandonedBronco
That should take care of it. Those valve covers can make a mess when they leak. Keep us posted.
What carb do you have on there now?
I'm really liking the 465 on mine.
Old Mar 18, 2015 | 09:32 PM
fordboy300's Avatar
fordboy300
The holley 600 on the dp!! When I put the C series I think I'm gonna run it with out the heat plate. Hopefully it works out good! I'm hoping I don't get any bogs!
rustywheel68
Jun 4, 2011 01:42 PM
Orange '63
19
Dec 21, 2007 11:49 AM
funnyboy
Dec 19, 2004 06:04 AM
Katmandu
13
Sep 17, 2004 10:54 AM
Farm Dog
Jan 4, 2003 10:57 PM
