View Poll Results: is anyone elses excursion cracking
yes my truck is cracking
0%
no cracks at all
100.00%
Voters: 4. You may not vote on this poll
excursion paint cracking
Old Jul 24, 2003 | 01:43 PM
ken mason's Avatar
ken mason
Angry excursion paint cracking
I have a 2000 black excursion limited that has cracks all over the paint. the local paint shop has found five layers of paint on it from the factory. Has anyone else had this problem. Ford denies it.
Old Jul 24, 2003 | 03:11 PM
Capt Dan's Avatar
Capt Dan
mine is a 2000 silver, but no cracks
Old Jul 30, 2003 | 10:04 AM
ExcursionUSA's Avatar
ExcursionUSA
I have a black 2003 X. But no cracks or paint mistakes here.
Sorry to hear your problem.
Old Jul 31, 2003 | 01:03 AM
ghittner's Avatar
ghittner
White 2001, No problems. Sorry about yours.....
Old Jul 31, 2003 | 05:51 AM
RBRADBURY9753's Avatar
RBRADBURY9753
I have a 2000 black X and have not seen any cracks yet.
Old Jul 31, 2003 | 06:24 AM
jschira's Avatar
jschira
'03 White X. Some orange peel, but no cracks.
Old Jul 31, 2003 | 08:28 PM
rp1's Avatar
rp1
I have a 2001 midnoght blue - no cracks - paint lookm good but I do have 4 bad door locks - especially in the heat
Old Aug 3, 2003 | 10:50 AM
jdadamsjr's Avatar
jdadamsjr
'03 ALL black - including grill and bumpers - 5 months in DFW, Texus heat - never garaged - no problems...
Sorry to hear the paint issues...
Have you taken pictures and sent them to Ford Corporate?
Did you buy it used?
Old Aug 10, 2003 | 07:15 PM
chitownrepoman's Avatar
chitownrepoman
I have a 2000 X.....the paint on mine around both rear lower door window frames is actually peeling off.
Old Aug 15, 2003 | 03:56 PM
rp1's Avatar
rp1
take it to ford and start to argue- do not stop at the dealership - keep going up the ladder. it should not peel off, this has to do with paint not adhearing correctly to the primer. GM had this problem years ago and if you pushed hard enough you can get results. The exception in how may miles on the X? IF over 75,000 good luck
Old Aug 18, 2003 | 11:06 AM
DW2455's Avatar
DW2455
did you buy it used? if so it may have had pryor damadge, Thnx DW
Old Aug 18, 2003 | 07:20 PM
rp1's Avatar
rp1
I did buy it used, it came with a ford 100,000 mile extended warranty. It had 37,500 miles on it. No it was never in a wreck or any body damage. chitownrepoman has the paint peeling. It sounds like a poor blow and go paint job for some type of damage or defect, however I have known vehicles to be re touched at the factory so this could be the case as well. I have a friend that repaints defective finishes on vehicles coming off the factory line. that is all they do, so I would investigate further.
Old May 17, 2004 | 08:05 AM
ExcursionUSA
I washed and dried my truck over the weekend and I was shocked when I looked at the driver door. It looks like little hair scratches, but it is underneath the clearcoat. Can't feel or see any impact of like stones, plus it is all over the place. Looks like somebody painted paint brush hairs in it... also discovered some on the rear door, which looks almost like it is cracking underneath the clearcoat as well...
I think I'll have to talk to the dealer and Ford Co... I'll let you know...
Old May 17, 2004 | 09:38 AM
jdadamsjr's Avatar
jdadamsjr
What year and what color ?
My black 03 has hairline scratches all over...
but those are MY fault...
and includes the LARGE scratch on the back doors that I did lifting something in the hatch :-(
am getting a bud from northtexaspowerstorkes.com that does "refinishing" for dealers to help with that this Friday...
Have seen his work and the b4 and after pics are amazing!
Will be doing the same for this process too...
and let you know...
Old May 17, 2004 | 10:04 AM
smassie88's Avatar
smassie88
2000 Black X with what appears to be the paint peeling off the the tops of the hinges for the rear glass and some cracks in the outer most roof indentation on both sides. Just noticed last night while washing. Will try to check further in the next couple of days.
