trying to pick a cam
Old Mar 16, 2015 | 10:46 AM
HVACTOM's Avatar
HVACTOM
Hello all I am trying to choose a cam and going with a 524 524 for a ford 400 Cid it says it's a lope idle what is the down fall to this should I find one smaller? Thankyou all for your time.
Old Mar 16, 2015 | 10:53 AM
Conanski's Avatar
Conanski
What trans, gearing, and tires does the truck have?
What do you use the truck for?
What kind of powerband do you want?
Old Mar 16, 2015 | 11:01 AM
HVACTOM's Avatar
HVACTOM
it has a c6 trans and 15 inch tires I just want something that is good for the street and the only reason I wanted loap was sound but I want low end to mid range power. This is my first build I'll put up a link to this cam it says that the stall and gears not need to be changed just aprings
Old Mar 16, 2015 | 11:49 AM
bkaul's Avatar
bkaul
A cam with bad idle is going to be one with lots of duration and overlap that's set up for high-rpm power. Great if you're building a race car and spinning your engine at 6000 rpm + all the time, but the wrong direction to go for a truck, IMO. One that's good for low-to-mid-range torque will generally have a fairly nice, smooth idle.
Throw Flowmasters on it and set the idle speed a little on the low side, and you'll have a pretty good, low tone though.
Old Mar 16, 2015 | 12:03 PM
HVACTOM's Avatar
HVACTOM
Ok that's what I hear guess I'll go smaller to .494. 262 duration
Old Mar 16, 2015 | 12:05 PM
Conanski's Avatar
Conanski
If the motor is all stock then it won't benefit from a radical racing cam, pick something that is designed to work in the rpm range you will use which in this case will be something with about 260-270deg total duration(200-215deg 0.050" duration), and about 0.450-0.500" lift. You could pick something a lot more radical that will sound all bad assed but that's all you will get.. sound, you won't get useable power.
Old Mar 16, 2015 | 12:09 PM
HVACTOM's Avatar
HVACTOM
This smaller but says I need 9.1 compression and I think mine is 8.1 What do ya think?
Old Mar 16, 2015 | 12:11 PM
HVACTOM's Avatar
HVACTOM
The only mod is headers and intake and carb. It's a rebuild engine almost done.
Old Mar 16, 2015 | 12:13 PM
HVACTOM's Avatar
HVACTOM
If I mill heads I can get 9.1 comp but then I need to mill intake and make push rods shorter?
Old Mar 16, 2015 | 12:30 PM
Conanski's Avatar
Conanski
Why can't you go another step down to something like this.. http://www.summitracing.com/int/part...view/make/ford
Old Mar 16, 2015 | 12:42 PM
HVACTOM's Avatar
HVACTOM
This one has a review and the guy used stock springs. Trying to save every penny also since carbs cost so much.
Old Mar 16, 2015 | 01:31 PM
HVACTOM's Avatar
HVACTOM
Thankyou for talking me out of the big one I'm ordering the last one I posted I will update once she is running. Thanks again guys!
F-250 restorer
27
Jul 18, 2017 07:39 PM
hustler54
Mar 23, 2013 08:58 AM
gudor
Apr 1, 2012 12:31 PM
all go no show
Oct 4, 2004 07:30 PM
ScottJM
23
Jan 4, 2004 01:17 PM
