please help identify reared
Old Mar 15, 2015 | 08:47 PM
exam's Avatar
exam
My truck was custom built i dont know if this is the rearend that came with the truck and i gotta replace the rear yoke. there showing three diffrent rear yokes for a 2000 model f350 2wd
Old Mar 15, 2015 | 09:41 PM
DattMavis's Avatar
DattMavis
I'm pretty sure its a Dana 80. What you're showing there is the part number for the cover (47717-1) Is there a metal tag/band near the bottom held on between two bolts? That should show your gear ratio and if it's limited slip
Old Mar 15, 2015 | 09:49 PM
DattMavis's Avatar
DattMavis
Also, on the axle tube, probably the passenger side, there should be a 7-digit number in this format: XXXXXX-X. That's your Bill of Material number, and it would allow you to identify it exactly
Edit: it could also be on that tag mentioned in my previous post.
Old Mar 15, 2015 | 10:12 PM
exam's Avatar
exam
Ok thanks ill check it tommorow Thanks again
Old Mar 16, 2015 | 06:59 PM
exam's Avatar
exam
No luck today i was unable to read the numbers on the axle the onlything on the tag was a 10 i was told today by shop there showing like 4 diffrent rear yokes im stuck like chuck!!!
05MilMachine
Nov 26, 2016 02:17 PM
jwhopson
16
Jul 14, 2013 07:09 PM
Eclipseb2k2
Apr 14, 2008 02:47 PM
walt80
Mar 18, 2004 03:44 PM
whalerron
Jan 22, 2003 11:27 AM
