Power Steering Conversion
Old Jul 24, 2003 | 12:00 PM
Highboy70's Avatar
Highboy70
Well I finally got the pictures of my conversion in My Gallery. The gearbox is out of a 1978 F250 4x4. You may wonder why I'm not in the 67-72 forum, well the frame I have is a 1974 4x4.
I have driven the truck for about two weeks now with no complaints. Of course taking the whole front clip off made this so much easier to do, but I already had it off for the Cab mount replacements. I will try to get some pics of the whole truck and the PS conversion with the rest of components installed. If anyone is doing this I can recommend some do's and Don'ts, I will try to type up a narrative of the whole project if anyone wants it.
Old Aug 10, 2003 | 10:24 AM
scamardo's Avatar
scamardo
Hey, I am replacing my 65 steering column for a 73 p/s column. Do you have any info on the wiring? My 65 has 7 wires and the 73 has 11. Just trying to find out exactly what goes where from someone who has done it before.
Tim
Old Aug 11, 2003 | 09:45 AM
Highboy70's Avatar
Highboy70
Tim,
Here's what I did. I took a 75 4wd column and my original 70 2wd column and pieced them together to make it look original, but still work correctly. I used the steering wheel,shift collar, outside tube and turn switch and wiring off the 70, and then I used the center shaft and end bearings off the 75. This allowed it to mate up to the 4wd power steering gearbox yet still look original inside and not change any wiring hookups.
But this may not be a solution for you. So if you would like I will look in my 66-76 Mitchell Wiring diagram book at home and get you a list of the wiring and color codes.
You know I could even fax you a copy of both of the wiring diagrams fo future reference.
I'm at work now and will dig out the manual when I get home? I hope anyway, I just got done moving and everything is still boxed up.
Ralph
Old Aug 11, 2003 | 11:21 AM
scamardo's Avatar
scamardo
That would be great Ralph. shoot me an email off-post for my fax number.
I sure do appreciate it.
Tim
tscamardo@carolina.rr.com
Old Aug 12, 2003 | 04:37 PM
Highboy70's Avatar
Highboy70
Tim,
Good news! I found the book with all the schematics. I tried to E-mail you, but it must not have gone through. Here's mine
ralph.moore@eielson.af.mil
as soon as I can copy them and get to a Fax machine their on their way. There will be two pages for each schematic. Just from looking at them, I think your extra wires are for the emergency flasher system. On later trucks they put them on the column. Mine have been either in the glovebox or in the dash.
ralph
