power steering help
Old Aug 12, 2003 | 10:18 AM
pauleepee's Avatar
pauleepee
power steering help
I have a 79 f-250 4x4 and the power steering jerks when I turn. I have replaced the hoses and it does'nt leak....help
Old Aug 12, 2003 | 11:04 AM
Hunt-with-a-bluetick's Avatar
power steering help
Air Lock try bleeding the system
Old Aug 12, 2003 | 04:44 PM
Highboy70's Avatar
Highboy70
power steering help
The best way I've found to bleed mine is to jack up the front end to just barely touching the ground, then start the engine and turn the wheel fully to left and right slow. Check your fluid level often. This should take care of any air you might have.
