Up Pipe Options
Old Mar 18, 2015 | 10:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Originally Posted by pinbill
I went to the dealer today. The parts guy said they were $28 a bolt. Then he said "those diesel parts are expensive." I have the parts numbers and I will get some of the internet.
lol. That's pretty funny. I got a couple from ih and they were $7 a piece. I thought I was getting ripped off there but FORD FOR THE WIN. lol
Old Mar 29, 2015 | 10:30 PM
pinbill's Avatar
pinbill
Well I got the the truck back together, started it up, no fuel leaks, runs decent. I am getting no boost and the egts spike very quickly. I have been over the connections a bunch of times. There are no rips in the boots and everything is tight. The fan is spinning and everything worked before I took it apart. The up pipes went together nice so I really don't think they are leaking. It seems like I missed something stupid because there is no boost at all.
Old Mar 29, 2015 | 10:39 PM
oldbird1965's Avatar
oldbird1965
If you have a boost leak you should be able to hear it.
Old Mar 30, 2015 | 12:39 AM
fordman67's Avatar
fordman67
No boost when? You won't see any just free reving it.
Old Mar 30, 2015 | 08:04 AM
pinbill's Avatar
pinbill
No boost while driving under load with massive egt spike. It doesn't seem like a boost leak because the gauge doesn't move at all. The gauge was fine before. I checked to see if the turbo fan was spinning with the intake off with my wife revving it. It was spinning nicely. The bellowed up pipe gaskets are installed on both sides along with a new manifold gasket. Bolts torqued to 35#. I got a new gasket set for the turbo. There were 4 pedestal o rings in the kit and three larger orings. Two redish orange ones and black one. I put the smaller redish orange one between the turbo and spyder. I didn't see where the other two went. Maybe I missed something? Maybe I angered the Ford gods by not using the dealers bolts?
Old Apr 1, 2015 | 08:09 AM
DIYMechanic's Avatar
DIYMechanic
Is there a chance that one of the boots between the spyder and the intake plenums is cut or not on correctly? It's sometimes difficult to get them on the plenums and get the spyder into them without them popping off. If they're popped off on the bottom side of the plenum, you may not see it right away. The old, soft, orange boots tend to be easily damaged too if that's what you still have.
I would look at that plumbing before I would suspect the exhaust side. It would have to be a pretty big exhaust side leak in order for you to build 0 boost, and with a leak like that, I would think you would see and or hear it at idle. The air (intake) side....not so much.
Worst case, build yourself a boost leak detector and pressurize the intake side to about 15-20 PSI and spray everything down with soapy water. The bubbles will show you the leak, if it is in the intake side of the turbo.
Old Apr 1, 2015 | 08:48 PM
pinbill's Avatar
pinbill
Thanks for the tips.
I tried putting a board over the exhaust and listening for exhaust leaks. There was significant pressure at the tail pipe. I couldn't hear any exhaust leaks.
I will get the stuff to make the tester tomorrow.
How many gaskets/ o rings are on the intake side of the turbo? I only replaced the orange one on the spider.
Bill
Old Apr 1, 2015 | 10:28 PM
oldbird1965
This is what I made from stuff at Tractor Supply to put on the intake to pressurize the system.
Old Apr 2, 2015 | 05:55 AM
DIYMechanic
Here's a pic of what I came up with.
I take the aluminum elbow off the intake, insert this where the elbow connects to the intake boot and clamp it down. Dial the regulator up to the pressure you want, leave the hose hooked up to it and start looking for leaks. It works good.
Old Apr 2, 2015 | 08:00 AM
pinbill's Avatar
pinbill
That settles it. Tonight while my wife is at Yoga, I'm loading up the kids and heading to harbor freight!!!
Old Apr 3, 2015 | 09:30 PM
Dzldust's Avatar
Dzldust
8th Gear
any progress on your boost issue?
Old Apr 3, 2015 | 10:51 PM
91 Dually's Avatar
91 Dually
Check the hose going from the intake plenum to the map sensor. If that hose comes off, you will have no boost, no power.
Old Apr 4, 2015 | 06:02 AM
  #28
DIYMechanic
That hose has been know for getting old and crusty and leaking too...
Old Apr 4, 2015 | 06:44 AM
  #29
pinbill's Avatar
pinbill
Here is the progress update. I did go to Harbor Freight the other night and picked up the parts to make a boost detector. I have been too busy to work on the truck. But the WVO tank I ordered finally came in. I picked up Tuesday and it is going to be awesome.
I think the problem is the map sensor. Without looking at it (its still dark out) I hooked the boost gauge up to the spyder and I am sure there is an open tee in the map sensor line for the boost gauge.
My gut tells me I will hook everything up right this morning and then have a sweet boost leak detector to put on the shelf.
I will let you know.
Thanks,
Bill
Old Apr 4, 2015 | 06:07 PM
  #30
pinbill's Avatar
pinbill
Boost gauge was in the right place. Replaced the hose to the Map Sensor. It was cracked but still no luck. Breaking out the boost leak detector tomorrow.
