No Heat
Old Mar 14, 2015 | 05:10 PM
Jasonsb1980's Avatar
Jasonsb1980
No Heat
Had recently had overheating issues. I changed the thermostat and still overheating no heat. today I replaced heater core water pump and the radiator thinking all the tubes was clogged from stop leak and not flushing after the leak had stopped. All new cooling system and still no heat. I also noticed the know only turns half way when trying to switch to cold to see if ac was working. It only turns half way and then stops. Also seems like temperature gauge is reading cooler than what it really is. Anybody have any ideas or suggestions?
Old Mar 15, 2015 | 12:07 AM
aj88V's Avatar
aj88V
Do the two hoses to the heater core get hot? If they do, then it's got to do with the box around the heater core, the flapper valve, or the controls.
If they don't get hot, well then, that's your problem!
Old Mar 15, 2015 | 05:12 AM
broncoderek's Avatar
broncoderek
Did you figure out why you overheated in the first place?
My truck is sensitive to coolant levels and will overheat if there's air in the system. During those times I won't have heat due to nothing much flowing.
Make sure your entire system is fluid-filled with no air. Get it running and hot with the cap off then top it off, add the cap to build pressure and see if that helps. You may be surprised at how much more coolant you can fit in there.
If this is a dash-switching problem, ignore my entire post!
Old Mar 15, 2015 | 11:56 AM
tjc transport's Avatar
tjc transport
i ain't rite
what year truck, and what engine?
shadows4
Jan 23, 2019 06:53 PM
Chiver
1983 - 2012 Ranger & B-Series
16
Feb 6, 2017 06:12 PM
Grelda1975
Jan 31, 2016 03:32 PM
War Ji
Nov 15, 2014 06:55 PM
jimford1
1978 - 1996 Big Bronco
21
Feb 6, 2009 01:17 PM
