automatic steering column to manual
Old Mar 14, 2015 | 01:53 PM
772504x4's Avatar
772504x4
so i have a tilt automatic steering column... and unless its in park it wont turn over.... well id like to put a manual steering column in it since after today i bumped the turn signal lever and now the tilt wont lock.... thing is even after i find i manual how do i bypass that neutral safty switch so itll start since there is no park selector on a manual column
Old Mar 14, 2015 | 04:20 PM
bkaul's Avatar
bkaul
You can just jumper the pins at the connector and wire up a clutch switch instead. Your reverse lights also go through the same switch and will need to be re-routed to the reverse light switch on the transmission if you're swapping to a manual.
Old Mar 14, 2015 | 06:55 PM
772504x4's Avatar
772504x4
Id be happy if my tilt would just lock... i mean damn i only bumped the blinker lever
tony2uhand
Apr 30, 2018 01:03 PM
smitka66
Sep 8, 2014 02:48 PM
bmac4020
Jan 4, 2014 05:47 PM
texasjr
Sep 1, 2008 12:25 PM
rick
Feb 23, 2000 10:43 PM
