Axle code 53?
Old Mar 14, 2015 | 12:09 PM
Brnfree's Avatar
Brnfree
Axle code 53?
The axle code on my '86 E350 dually is "53".
What axle have I got and what is the correct lube?
Also, do I need to add any friction modifiers?
Old Mar 14, 2015 | 12:33 PM
Conanski's Avatar
Conanski
Here is one listing I found, another listing showed the axle ratio as 3.54 but that won't affect your questions. This axle has an open diff so you don't need friction modifier and regular 75w90 gear oil will do the trick.
53 = Dana 70 HD - Capacity 7400 - Ratio 4.56
Old Mar 14, 2015 | 12:53 PM
Brnfree's Avatar
Brnfree
Thank you Conanski.
I don't know much about gear ratios but I can say with the C6 I'm running about 2,750 RPM at 63 MPH on the highway.
When you say "open diff" does that mean it's not a limited slip or posi?
Because it seems like there is some chatter crawling up a grade with a sweeping right hand turn.
Old Mar 14, 2015 | 09:04 PM
Brnfree's Avatar
Brnfree
Well curiosity got the better of me so I paid the truck a visit, crawled under and found a rear axle tag.
3.54 gearing and not limited slip or locking, just like you said!
The code on the tag is 605300-1 and FWIW here's the Dana decoder site:
Dana Holding Corporation - The Expert Axle Bill of Material
Thanks again
Old Mar 15, 2015 | 09:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The AXLE code on the Certificaton Label is 53 but...in the Ford truck parts catalog, this refers to two different Dana 70's.
53: 1980/85 Dana 70 H/D / 4.56-1 / No Limited Slip / 7,400 lbs. Rear Axle Capacity.
53: 1983/89 Dana 70 or Dana 70U / 3.54-1 / No Limited Slip / 7,400 or 7,800 lbs. Rear Axle Capacity.
Beginning in 1959: IF the AXLE code begins with a letter: Limited Slip / If with a number: No Limited Slip.
Baja16
17
May 16, 2013 11:59 PM
Lonewolf0804
Mar 2, 2009 11:57 PM
nixon_ca
Feb 13, 2005 12:57 AM
rolinron
May 16, 2004 11:21 AM
GregCS
Mar 1, 2000 10:27 PM
