Motor mounts
Old Mar 14, 2015 | 09:33 AM
twise's Avatar
twise
Motor mounts
Just a long shot here but I am in need of a set of motor mounts for an inline six cylinder 250ci for a 69 mustang. If anyone can help me I would appreciate it. Thanks.
Old Mar 14, 2015 | 10:33 AM
HIO Silver's Avatar
HIO Silver
National parts Depot has about everything to build a complete Mustang from nothing. Go there.
Old Mar 14, 2015 | 02:06 PM
twise's Avatar
twise
Been there, none available. Thought maybe someone on here would have a set they would want to part with.
Old Mar 14, 2015 | 03:50 PM
dwhawkins89's Avatar
dwhawkins89
this is year one. Most noted for Camaros, but here you go
https://www.yearone.com/SearchResult...motor%20mounts
Old Mar 14, 2015 | 05:21 PM
twise's Avatar
twise
thanks guys. these motor mounts aren't being made by anyone. i've been told that i need to find an original set.
Old Mar 14, 2015 | 05:33 PM
HIO Silver's Avatar
HIO Silver
Question...actually, we need a clarification.... are you looking for the insulators or the steel brackets/arms?
Old Mar 14, 2015 | 07:39 PM
GLR's Avatar
GLR
Try
Home Page
Listing EG-368 67-69 RH or LH, 6 cyl
Virginia Classic Mustang
Old Mar 14, 2015 | 07:51 PM
twise's Avatar
twise
I seen those, thanks. I need the parts that bolt to the block. I've been told no one is making these right now.
Old Mar 14, 2015 | 08:26 PM
HIO Silver's Avatar
HIO Silver
Well that would have been helpful to know at the outset!
Read this for info: Ford Six Performance 200ci to 250ci Swap Notes
It looks easy enough to fabricate IMO... posterboard, a Sharpie, 3/16th plate, a welder, and you're in business.
Old Mar 14, 2015 | 08:33 PM
dwhawkins89
https://www.npdlink.com/store/produc...-105049-1.html
This?? IM with HIO Silver, im faily certain your parts are at NPD.
to the best of my knowledge (which isn't much), the motor mount is this. Other wise your looking for the mounts to the frame, which is also on NPD. If im wrong, let me know when you figure it out
Old Mar 14, 2015 | 08:38 PM
HIO Silver's Avatar
HIO Silver
OP isn't looking for the insulators... he's looking for the brackets that bolt on the engine to which the insulator mounts... basically there are three pieces per side to mount the engine - an engine-side bracket, the insulator, and a frame-mounted bracket.
Old Mar 14, 2015 | 11:55 PM
twise's Avatar
twise
HIO Silver is correct. I will take the insulators also but really need the brackets to the block. Thanks
Old Mar 22, 2015 | 10:19 AM
twise's Avatar
twise
HIO Silver, I have found the upper brackets and insulators. I have someone shipping them to me so as of now I need the arms. Thanks
peppersfords
1978 - 1996 Big Bronco
Mar 23, 2007 12:54 AM
barry58
Aug 17, 2001 01:46 PM
