Greetings, I would like to advise me on my engine carburetor. is a Y block 292 C2AE with heads ECZ-G, headings, 4-1 and electronic ignition, now I have a 2100 Autolite 1.23.
thx
The 2100 1.23 is larger than a 292 used. It can probably work if you have parts available to tune it. Since you have it, try it. The Autolite carbs are good, in general.
I can hardly make it work well, is giving me trouble adjusting it, once started going about normal but hit the brakes to stop off. you need to change to make it work on my engine?
