Hey, I want your pass. side door cladding if you still have it and it's my color (looks like it is). Previous owner of my rig thought the appropriate fastener for a loose section was a self-tapping metal screw.
Looks real nice.if your intrested in getting ride of the front passenger side fender cladding let me know.mine got shattered in in a accident.haven't found replacement yet.
Yes I plan do the bottom of the door too, am waiting to get the front bumper then do it,
I will add some pictures of the mounts I cut off and were I drilled the hole.
here a link for the bumper Froniter gear 100-10-8009 Mudflaps.com
I like that bumper. Do you know if the bumper they sell for the 02 F250 will fit the Excursion without modification? Why did you get the one for the 08+?
Studwg: am not sure if 02 F250 will fit, I just like the step on the ends of the bumper. Here what i cut off the mount, I cut about 1" off a time. And I will get one of the holes, one hole was the factor and one had to drill though the mount and the frame. And the mount on the bumper is weld to the bumper.
Well Guys
It’s done 05 headlights Grill and header panel. And Frontier Gear 600-10-5005 bumper, have to paint the grill white, still have to spray the running boards. Next will be a new spring!!!
Fwiw I did my fab fours fear bumper yesterday and today and I had to trim an inch off the top lip and chop around a foot of quarter inch steel off the brackets, and I had to trim all the lip off about ten inches on each side of the top, and trim some mounting gussets because their frame mounts are double triangulated to the frame and the I had to weld some stuff back in.
