Transmission hum
Old Jul 24, 2003 | 08:29 AM
hutch99's Avatar
hutch99
Unhappy Transmission hum
I have a 2000 f-150 SB. I bought it 4 weeks ago, has 45K miles on it.. It has a low hum between 56-61 MPH in overdrive, around 16K-17K rpm. Runs great, no idea if the trans. fluid has ever been changed. The low hum and vibration almost puts you to sleep in this speed range. Runs and sounds good at all other speeds and rpm's. Help
Old Jul 24, 2003 | 02:48 PM
Big Orn's Avatar
Big Orn
Transmission hum
Just a hunch - Have you eliminated the tires as being the problem?
Old Jul 24, 2003 | 02:55 PM
hutch99's Avatar
hutch99
Transmission hum
Yes, I think I have ruled out the tires. If I drop out of cruise control at 60 mph, and begin coasting down the hum goes away immediately, it appears to be only when actually using the overdrive.
Old Jul 25, 2003 | 12:20 PM
hutch99's Avatar
hutch99
Transmission hum
Just had the trans. fluid /filter changed. Sound and vibrations still there. Help!!!
Old Jul 26, 2003 | 06:22 AM
Snailbite's Avatar
Snailbite
Transmission hum
Check you differential fluid, my 97 F150 had to same symptoms, and the differential 1 1/2 pints low. If you have a limited slip, make sure you use only synthetic multi-weight oil with limited slip conditioner(you have to mix the two together).
Old Jul 26, 2003 | 07:19 AM
hutch99's Avatar
hutch99
Transmission hum
Thanks for the info. I am new to pickups. How can I tell if I have a limited slip differential?
Old Jul 26, 2003 | 08:32 AM
Snailbite's Avatar
Snailbite
Transmission hum
Take your numbers off the tag in the door jamb on the drivers side, it will have an axle code and transmission code and so on. A Haynes Repair Manual will have an axle and transmission codes in it. There is also a tag on your differential that tells you what kind of diff it is.
Old Jul 28, 2003 | 11:05 AM
hutch99's Avatar
hutch99
Transmission hum
Thanks, I did check the differential and found it to be a quart low. I still have the noise, but today the engine is missing out, it happens to be a rainy wet day. Now that I have serviced the transmission and differential, I am thinking the engine is missing causing the sound I am hearing between 56 and 61 mph. I think I will tackle the obvious on the engine. Things like plugs, fuel filter, and plug wires. Thanks for your help.
Old Aug 6, 2003 | 12:11 PM
hutch99's Avatar
hutch99
Transmission hum
Ended up taking it to the local Ford dealer for service. After 2 days they diagnosed the noise and vibration as a bad rear exhaust dampner. They replaced it and $291 later the noise and vibration is still there. They ruined my new floor mat getting in and out during testing. Now squabbling with Ford, most liklely won't win.
Old Aug 8, 2003 | 03:47 PM
fordin K's Avatar
fordin K
Transmission hum
So what was the noise, I have a low pitch noise also, but mine has to do with all the roof and cab panels resonating at certain rpm for tire. I just drive and it kicks in at certain range. but you can difinitely feel the resonation "pulses" in rhythm. you can tell if tires are doing it by driving on dirt road. the softness should throw off that range. if not could it be WHEEL BEARINGS ???
Old Aug 8, 2003 | 03:48 PM
fordin K's Avatar
fordin K
Transmission hum
I'm sorry wheel bearings would not be occasional just a blurp from me.
Old Aug 12, 2003 | 10:51 AM
hutch99's Avatar
hutch99
Transmission hum
The Ford dealer has replaced the ring and pinion and a bunch of other stuff inthe rear differential and after ($1400 of their money), it still has the vibration between 56-61 mph, 1700 RPM in overdrive. Next they want to tear into the front differential at my cost.
Old Aug 12, 2003 | 02:01 PM
Big Orn's Avatar
Big Orn
Transmission hum
Did you mean, when you drop out of overdrive instead of cruise control? And if you left it in 3rd gear would it NOT make the vibrations you are describing. For example: If you were to leave it in 3rd gear, get up to 56-61 MPH does it vibrate or not? If it does not vibrate then it would suggest a tranny problem ONLY. Do not let them tear into that front diff. If it still vibrates, then it could be:
1 - carrier bearing
2 - u-joint
3 - wheel bearing
4 - tires (still stuck on that - somewhat)
5 - pinion bearing (unless they replaced that too)
Also - does it vibrate under load as well as coasting in overdrive in that speed range?
Old Aug 13, 2003 | 09:28 AM
hutch99's Avatar
hutch99
Transmission hum
Big Orn,
I tested it again last night, at 56-61 mph in overdrive the noise and vibration is there, in 3rd gear at the same speeds it's there also, only at a different frequency because of the higher RPMs, but it's still there. Everything is very smooth at all other speeds, you can't even hear it running. I don't mean it's shaking, the sound is more like the engine laboring. In overdrive the sound is like driving over rumble strips at those speeds. Thanks for the help.
Old Aug 13, 2003 | 09:45 AM
Big Orn's Avatar
Big Orn
Transmission hum
I really hope someone with more auto tranny knowledge than I have will jump in here, but with the symptom you describe - "Still there but at a different frequency because of the RPM's" - would suggest the front half of the tranny, like a bearing or loose torque converter. If the RPM's of the motor determines the rumble/vibration, and if the motor is not misfiring, and the pulleys/belts/fan/pumps are good, then all I can think of is the front half of the tranny.
